Leaking Gas as Cap
Old Jul 31, 2009 | 09:29 AM
gwrichard's Avatar
Leaking Gas as Cap
I have a 1986 Pontiac Firebird with the 2.8 V6. I have had the gas tank replaced hoping to have the problem rectified, yet no avail. I have gone through 4 gas caps and all have leaked. An interesting problem I noted is that the threats on the aftermarket caps are too deep and have to be trimmed in order to fit the treads on the filler neck.
I have lessened the amount of gas leaking by using non-gas soluble liquid gasket on the gas cap, yet the car still consistently leaks with a 3/4 full or higher tank of gas when making right turns and accelerating at anything more than a snails pace.
Have any other owners run into this and if so how was it corrected?
Thanks,
Greg
Old Jul 31, 2009 | 03:51 PM
87_Injected's Avatar
Car: 2010 2LT RS
Re: Leaking Gas as Cap
You must have the wrong gas cap on the car then.
Old Aug 2, 2009 | 07:03 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I have the same problem on my 84 TA. I have tried gas caps from dealer and no help. I really don't want to change the tank and it still have same problem.
I have owned this car since 1991.
Old Aug 3, 2009 | 10:44 AM
1Aauto's Avatar
Former Sponsor
Thanks,
Greg
Is the little flap in the fuel filler tube intact.That should keep most of it from sloshing out.
Old Aug 3, 2009 | 11:51 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
YES the flap is there.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
wayshegoes
Aug 17, 2015 12:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
