door lock set
Old Aug 3, 2009 | 08:48 PM
draco's Avatar
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
door lock set
Does anyone here know of a vendor that sells a lock set for our f-bodies that includes doors, hatch, and t-tops?
Old Aug 4, 2009 | 01:09 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: door lock set
Did you just lose the key or just want a new set of locks?
If just a lost key you could pull out just ONE door lock and take it
to a locksmith and have a keys made for less than $15 bucks.
Old Aug 4, 2009 | 01:16 AM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: door lock set
I need to know as well. one of my doors was replaced by the PO but they didnt switch the lock...
Old Aug 4, 2009 | 06:05 AM
draco's Avatar
Engine: 5.0l TBI
Re: door lock set
Actually, previous owner lost the t-top keys, broke out the hatch lock cylinder, lost the key for the locking gas lid, AND lost the door key. I really don't want to have 3+ keys for one car so I'd like to just replace them all with a matching set.
Old Aug 4, 2009 | 11:28 AM
1Aauto's Avatar
Former Sponsor
Re: door lock set
Did the T-Tops/Doors & Hatch match from the factory?
Old Aug 4, 2009 | 11:53 AM
AmorgetRS's Avatar
Re: door lock set
The t-tops, doors and hatch all used the same key from the factory. I've never had a locking gas lid, just a locking gas cap, but I would guess the lid uses the same key as the factory. The locking cap does not from my experience, but those all may be aftermarket.
Old Aug 4, 2009 | 03:49 PM
draco's Avatar
Engine: 5.0l TBI
Re: door lock set
the fuel door is most likely aftermarket, but its really not that important. Locking the doors, however, is a little more important. Also, does anyone know a good way to open the rear hatch when there is no lock cylinder?
Old Aug 7, 2009 | 03:21 PM
thumper9179's Avatar
Car: 1988 Firebird
Re: door lock set
Doors, tops and hatch use the same key. My passenger door was a replacement and had a different key from the rest,plus I had lost my only key to the other locks.
My local locksmith was able to create a key from the door lock itself to fit all locks and sold me a new lock for the odd door lock and keyed it to all the other locks, so now they all work correctly from one key.
Your local locksmith is the answer.
Scott
Old Aug 7, 2009 | 03:27 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: door lock set
Scott
i agree. i have gotten parts from other cars and i just take my key with the new lock and they key it for me. less than 10.00.
Old Aug 7, 2009 | 04:44 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: door lock set
If your car has the little light in the rear cargo panel, than you can pull the lens off and stick a flat headed screwdriver in the latch, and turn it, and it will open. You'll notice where to put the screwdriver when you look in there. If you dont have that little light, than you can pull up on the rear plastic panel, and feel for the cable and pull, of course this method is a last resort, as you risk breaking something.
Old Aug 9, 2009 | 12:25 PM
draco's Avatar
Engine: 5.0l TBI
Re: door lock set
alright, I got into the hatch, that was fun.....
now for the locks. I'm calling the locksmith tomorrow and see what kind of deal he can work with me.
Old Aug 9, 2009 | 02:55 PM
Mudskunk's Avatar
Car: 1989 Formula 350 / 2001 TA WS6
Engine: 350 / LS1
Transmission: Auto / Auto
Re: door lock set
i got a replacement set from GM for the driver passenger and trunk. not sure the price yet as i was so frustrated trying to find em i just called and asked em to get me a set. they said no problem we will call you witht he price and should be here next week. last time i had that done to my wife's grand am it was around 90$ for 3 cylinders. hard to find working used ones in good shape. each cylinder should run around 30$ with key new. may be +- a few bucks.
maybe you have better luck finding used working ones than i ever have.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
g.l.mos
Aug 22, 2015 12:02 AM
