Do fenders match?
Old Aug 21, 2009 | 09:21 AM
92birdy's Avatar
Car: 1992 Firebird
Engine: 3.1
Do fenders match?
ok so after i just got done with all that body work i wrecked..... sooooooo does a fender from a 91 camaro match a 92 firebird? or what about an 87 or 88 camaro... im goin to the junkyard and wanna get the best one with the least rust hahaha
Old Aug 21, 2009 | 09:59 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Re: Do fenders match?
Camaro and Firebird fenders do not interchange. The only exterior sheet metal pieces that are the same is the roof, doors, and hatch panel.
Old Aug 21, 2009 | 10:05 AM
Stephen's Avatar
Car: 87 GTA
The only real difference between the various years of Camaro fenders vs other Camaro fenders, or Firebird fenders vs other Firebird fenders, is the ground fx mounting holes.
Different years ground fx have different mounting holes, but it isn't a big deal to drill new holes if needed.
Old Aug 21, 2009 | 10:59 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Are you sure about that? I'm 90% positive I have a firebird fender on my Camaro right now...it bolted right up and all the lines matched.....
Old Aug 21, 2009 | 11:13 AM
Stephen's Avatar
Car: 87 GTA
And I'm 1000% sure you don't. The Firebird noses are much lower, past the strut towers. Not even the hoods will swap.
Old Aug 21, 2009 | 12:04 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
They are incredibly different and can not interchange without swapping the entire front clip. It's obvious just looking at them. Confuzed1, how'd you compile thousands of posts here without ever looking at thirdgens? hehe
Old Aug 21, 2009 | 06:36 PM
Njs305t/a's Avatar
Car: 1987 Trans Am
Axle/Gears: 2.73 posi
The fender flares are also different.
Old Aug 21, 2009 | 07:54 PM
Confuzed1's Avatar
Car: 83Z28 HO
OK,OK....geeez...I got it out of a boneyard. I thought it was a bird I got the fender off of...sounds like it wasn't. It could have been a bird that had a Camaro front clip on it??
JeremyNYR - I guess this is how I've compiled thousands of posts...
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
rusty vango
Sep 29, 2015 02:44 PM
