front bumper install
Old Sep 20, 2009 | 04:42 PM
afida15's Avatar
Is there supposed to be just two or four spacers in that area that i have circled? and is there supposed to be any on the other side? thanks
Old Sep 20, 2009 | 05:16 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Re: front bumper install
Mine only had 1 set on each side when I pulled it off.
Old Sep 20, 2009 | 05:25 PM
Stephen's Avatar
Car: 87 GTA
If by "spacers" you mean the mounting brackets.....Only 1 per side.
Old Sep 20, 2009 | 05:37 PM
Stephen's Avatar
Car: 87 GTA
Old Sep 20, 2009 | 05:58 PM
FLYNLOW92rs's Avatar
Is there a How-To or schematic available for the 91-92 version?
Old Sep 20, 2009 | 06:08 PM
Stephen's Avatar
Car: 87 GTA
All 3rd gens use the same style. Only differences are the impact bar on 'birds is shorter width & the early o3rd gens had aluminum ones.
4 studs per bracket, 4 nuts. If your car the cooler lines on it, there will be an extra nut on the bottom.
Take that nut off, slide the cooler line bracket off, take the other nut off, that actually holds the brackets on.
And of course....The urethane nose has to come off first.
Old Sep 20, 2009 | 06:23 PM
Old Sep 20, 2009 | 06:36 PM
Stephen's Avatar
Car: 87 GTA
No How-to that I know of.
I just start taking stuff that attaches to the nose until it comes off. Hood latch bracket.
The underbody under the nose....
3 nuts per fender (I've found them easiest to reach, by popping the side marker lights out (just spring loaded clips hold those in), studs are part of the nose...
Been quite awhile since I've done a Camaro nose, but it was WAY easier than my GTAs nose, with all it's air direction stuff
Just keep track of everything & you'll know where to put it back. You can get you some little can (i use soup cans)/plastic bags (i use those to) or a piece of cardboard to write on& "stab" bolts in to.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
