locked out with engine running
Car: 89 IROC-Z
Engine: 5.7 liter
Axle/Gears: Stock
last night I stopped my camaro to get something out the trunk with my engine running, my lights on and I closed my door and it locked. and my windows were up! my alarm auto. locks when I turn on the ignition. well I tried using a slim jim but couldnt open it so I had to call AAA they unlocked it about 30 sec with some air bag they put between the window and use a long pole of some sort to push open my auto lock button. thankfully I didnt run out of gas waiting! that was the first time this happened to me. my spare remote didnt work because the car was running. does anybody know how to unlock the door with a slim jim? thankfully I didnt scratch the glass also
Re: locked out with engine running
I used a long stick to get the window bent enough to hold it with my hand then used the same stick to manually push the lock slider or whatever it's called. This was before i had my alarm, now I have a spare remote.
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Put a hide a key in the front impact bumper. Wife and daughter has locked themself out a few times
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
that happened with my old truck. it was gay. but it also happened while engine off in my t/a. I used to watch that tv series FRIENDS<that episode when they got a bunch of chop sticks and taped them together to poke the "ugly naked guy" they wanted to see if he was dead or alive. but anyways i did that took thirty minutes, i broke up like 9 plastic hangers and used the straight plastic bottoms taped together. works by press the button switch. yay.
Car: 86' Z28
Axle/Gears: 2.73 (for now)
I felt a little awesome when i locked my keys in my car at walmart saturday. I remembered how i got in it the last time, cept this time i used my antenna. I pried the window away a little with a screw driver and had someone hold it. Then I used the end of my antenna to push the handle on my t-top till it was unlocked. I felt a little cool
. Trending Topics
Car: 86' Z28
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Car: 89 Firebird Formula
Transmission: Five speed
Yeah that happened to me once my driver side door handle broke off went threw the passenger side unlocked the driver door but didn't open it then locked my passenger door and shut it talk about a world of **** but got my driver door open in the weirdest possible way a snow scraper and a bow from a bow and arrow
Car: 1989 GTA
Engine: 5.7 350
man i guess i should consider myself lucky. My car has no exterior lock cylinders so i have no way to lock my doors from the outside. Thus i have no fear of ever locking my keys in. Not very safe but i am installing a Viper alarm with door poppers so i should be good for the summer.
theshackle
Mar 5, 2017 06:37 PM
