Wide body rear????
Old Sep 29, 2009 | 08:53 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Wide body rear????
Tried a search with not much luck.... Wodering if any on here have gone for the wide body rear look on a 3rd gen... I'm trying to stay within the parameters of a stock tub, but considering widening the rear a tad on my '82 to accomodate some bigger meats....
Any input, good or bad, is appreciated.
Old Sep 30, 2009 | 01:36 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: Wide body rear????
Neil did a nice job on his.
https://www.thirdgen.org/forums/body...one-phase.html
Old Sep 30, 2009 | 08:30 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Thanks for the link to Neil's car, it does look great!!!!
Old Sep 30, 2009 | 08:53 AM
Stephen's Avatar
Car: 87 GTA
And it 100% custom & ALL STEEL.. In other words, it wasn't cheap/inexpensive, nor easily done by just ANY shop. It takes real skill to pull off what Vintage Rest did on Neil's car.
You can get the fiberglass panels, from ASCD/Stinger.....
ASCD Wide Body
Old Sep 30, 2009 | 10:12 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Neil's car is the nicest Camaro I've ever seen. There's definitely a lot of time, effort, skill, and money in that vehicle and the results are amazing.
Old Sep 30, 2009 | 07:53 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Obvious that Neil didn't cut any corners or get in a hurry on the build.... Still thinking on the wide body idea, definitely have to do it in steel... 'glass and steel just suffer from compatiblity issues after a few heat-cool cycles....
Old Sep 30, 2009 | 08:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
out of curiosity, what size tire are you thinking about using?
Old Sep 30, 2009 | 08:54 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Probably something in the 10.5" to 12" for a street tire, 10 or 10.5 for a slick... With a bit of trimming I can get 9.5"-10" in the wheel well as it is now....
Old Oct 1, 2009 | 08:11 PM
p100ki's Avatar
I like the ones on the back of this car, i like the way they flow onto the doors.
Custom Camaro. Handmade body. Widened over a foot, lengthened 11.5", modified Corvette ZR-1 rear, Ferrari Hatch with custom spoiler molded. Over $50,000 invested in car. Full custom body- NEEDS TO BE FINISHED with fiberglass. Built by John Silva, the original builder of the Mako Shark Corvette and designer of the Dodge Viper. This car will be worth a ton when done. Roll cage, 10 disc CD changer, custom painted dash, extra seats, engraved windows. Tons of extras- hoods, hatches, shocks, etc. Built 305 cu.in. Holley 4bbl, TH350 tranny with shift kit, 10 bolt posi with 2:73 gears. Spins second gear with 12" wide tires. Now it has 14.5" wide Mickey Thompson "I-pattern" tires in rear, 12" wide in the front on Cragar "Street Star" wheels. So many modifications and add-ons to list. Must sell. Need storage. Make offer or interesting trades?? Street rod?? Runs and drives. Own a one-of-a-kind mean looking car. No other like it. E-mail Scott
http://newhaven.craigslist.org/cto/1362732875.html
Old Oct 1, 2009 | 08:46 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
all that work with a lame hood and a carbed 305...
Old Oct 1, 2009 | 08:57 PM
Stephen's Avatar
Car: 87 GTA
Because it was a prototype/show car that had no need for any performance. No need for 1000hp, for something that drives no further than from one work building to another, or on & off a trailer.
Old Oct 1, 2009 | 09:32 PM
p100ki's Avatar
I'd take it off his hands if there was an easy way to get it on a trailer and back to ohio. I wouldn't trust my normal shippers to get it on a trailer and i know i would never get it on my trailer. I'd take off the pointy stuff and put a stockish front bumper on it.
Old Oct 2, 2009 | 12:25 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
That thing would be SICK painted black!
Old Oct 2, 2009 | 03:44 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Good God, look at that front overhang! Like it's not bad enough stock...
Old Oct 2, 2009 | 06:36 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
ASCD Wide Body
It may be just me, but I absolutely love how this camaro looks.
Old Oct 2, 2009 | 09:11 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
personally, i would go for a rear widebody kit, but i think the front should stay stock
im not a fan of how the front fenders meet up with the doors in this kit
Old Oct 2, 2009 | 09:29 AM
Stephen's Avatar
Car: 87 GTA
Almost a certainty, that the front and/or rear bumpers would hafta come off, to get the car n a ramped trailer. Unless you had LOOOOONG ramps, to make the angle real shallow.
Old Oct 3, 2009 | 12:11 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Yup, me too.... I do like the looks of the rear fenders...they would look better if the car were lowered a bit! Think I'd get a nose bleed sitting that high in the air!!!!!
Old Oct 6, 2009 | 11:13 PM
Uglybronco's Avatar
Car: '70 Bronco, '91 Firebird, '03 Chevy
Engine: roller 302, 350 TB, stock 6.0
Transmission: NP435 Granny 4 spd, 700R4, 4L80E
Axle/Gears: 4.56 spool, 2.73 open, 4.10 broken
That's nasty. I think a barf bag should be standard equipment for that.
I was looking at my car from a couple different rear angles the other day. I was tempted to bust out the grinder & cut off wheels and start pulling the quarters out in a kinda "Neil-ish" fashion. & kind of making them go more straight down instead of curving in so much. The problem then would be trying to make the '91 GFX work & blend right and then getting a loan to buy tires to fill them.
Old Oct 7, 2009 | 08:16 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
I haven't cut anything yet either... going to get the tires and wheels first, then build the rear end and fenders to match.....if I do it at all...
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
