look what i did xP (pics)
Old Nov 14, 2009 | 01:09 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
so..this morning i got bored and decided to take off the ugly black plastic peice that always scrapes the driveway when i pull in....AND i welded some new tips on =]
Attached Thumbnails look what i did xP (pics)-getachment.aspx.jpg   look what i did xP (pics)-1111091157.jpg
Old Nov 14, 2009 | 01:18 PM
Grants89iroc-z's Avatar
Car: 1989 Chevrolet Camaro iroc-z
Engine: 350 Tpi
Transmission: t5 Tranny
Axle/Gears: 3.08
Re: look what i did xP (pics)
lol that piece helps your car run cooler
Old Nov 14, 2009 | 01:22 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
you NEED the airdam, trust me, i thought it was ugly too
Old Nov 14, 2009 | 01:25 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by novafirebirdguy
you NEED the airdam...
JamesC
Old Nov 14, 2009 | 02:41 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
You need that piece to keep cool. I just ordered one for my 89 RS because it doesn't have one (missing when I bought the car). I've been putting it off because my fan switch is shorted and the fan runs all the time, but I have the parts to fix that too. The only time I've overheated is when my fan motor burned out.
Old Nov 14, 2009 | 02:52 PM
Engine: 350 Tpi
Axle/Gears: 3.08
you actually DONT need it, but it makes a big difference in cooling. My dad ran his iroc without the air dam fer years and it was fine, just was really hot! But once he put it back on it was wayyy cooler
Old Nov 14, 2009 | 03:08 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Those aren't those ri5er tips that point up at the end are they?
Old Nov 14, 2009 | 03:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well no ****, thats why you do NEED it, its the only way air gets directed to the rad when the car is moving.
OP, put it back on.
Old Nov 14, 2009 | 03:21 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Thank you for proving that you DO need it.
Old Nov 14, 2009 | 03:29 PM
toomany's Avatar
Camaro's have an air inlet in the front bumper. Altough some cars (TPI) have the air intakes down there. Firebirds are true bottom feeders, no openings in the front. I saw one TransAm that lost its air dam, the guy didn't know any better so he took a hole saw and cut a bunh of hole into the bumper cover for air flow.
Old Nov 14, 2009 | 04:20 PM
bearcats20's Avatar
Car: 1991 camaro Z28
Engine: 5.7 350 TPI with a performance chip
He's right the Firebird has NO opening for air unlike the Camaro's I have a TPI the air dam and the previous owner ripped it off and it ran almost to hot to drive. So I didn't drive it until I put another one on it.
Old Nov 14, 2009 | 05:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
:agree: You must have the "ugly piece that always scrapes the driveway" ie air dam under the car - otherwise you'll overheat at highway speeds - the fans don't provide any flow at highway speeds, and the air dam creates a vacuum that sucks fresh cool air through the radiator.
On the tips - I'd be concerned that the heat they will build up will melt the plastic rear bumper cover - looks like they are touching now. Also, exhaust needs to move freely with engine movement - that's why they hang it instead of attaching it to the frame - with it touching the rear cover, they are going to vibrate and rub marks into the rear cover, and along with the heat generated, you might ruin that rear bumper cover, which isn't cheap to replace!
Old Nov 14, 2009 | 07:06 PM
Engine: 350 Tpi
Axle/Gears: 3.08
Yeah it makes it run cooler, but im saying if you take it off, the car will run hot. But you WONT overheat. So you DONT need it, its just a big help.
You should be fine if you drive with it off.
Old Nov 14, 2009 | 07:23 PM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
from personal experience in my TA.
Yes you do need that piece for cooling.
It will overheat at highway speeds.
Cooling has always been an issue with my TA!
I fixed for good and for the last 5 years, 195 is the hottest it has ever gotten!
The camaro has the two openings, where the driving lights usually go, that would assist in cooling at highway speeds where the Firebirds do not!
If you have driven your 3rd gen without that ugly looking air dam and did not overheat, you are very lucky!
Old Nov 14, 2009 | 07:49 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
lmao at op
Old Nov 14, 2009 | 08:51 PM
Engine: 350 Tpi
Axle/Gears: 3.08
Thats true, i didnt realize the camaro was the only one with the opening by the lights!
Old Nov 15, 2009 | 12:31 AM
depends on were you live, 70mph on 110* day in vegas and it will overheat. A nice cool autumn day in Jersey, different story.
Old Nov 15, 2009 | 01:46 AM
Engine: 350 Tpi
Axle/Gears: 3.08
yeah hes in so-cal so he shouldnt have a problem lol, but yeah vegas would probly be too hot!
Old Nov 15, 2009 | 10:35 AM
Car: 1992 RS
Engine: Carbed 350
NC is too hot in the summer - we average mid 90's for highs - I'd see what I could do to make it pretty again, and reinstall it.
Old Nov 15, 2009 | 11:16 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
wow...alright....
my verdict:
1. put the air dam back on?
2. cut the tips off and putt the old ones back on (chrome tips that point down)
3. ask around the forum before i do anything else again xP
thanks guys.
Old Nov 15, 2009 | 11:20 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
#1.. put the air dam on because its is likely to cause running issues with your car.
#2.. the tips are cosmetic, thats your choice.
Old Nov 15, 2009 | 11:22 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
well they DO point up (ri5er status) but whatever...and its already blackened the back bumper a bit....
Old Nov 15, 2009 | 11:33 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Is it possible to just loosen the tailpipes at the clamps and rotate them down away from the bumper?
Old Nov 15, 2009 | 11:35 AM
if they blackened the bumper than they're probably going to start warping it too. if you like em see if you can lower the whole tailpipe, although that might make them look stupid.
Old Nov 15, 2009 | 12:13 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
+1 on the airdam(n) thing. had my formula overheat badly once moving over 42mph because that's when the fan shuts down. that's where you need the airflow from the airdam, plus it will supplement air feed to the radiator when the fan is on as well. and around here it rarely goes over 90° on hot summer days. had that happen with a new radiator.. it boiled over again and again till i added the airdam the preowner had taken off. no more problems after that.
Old Nov 15, 2009 | 12:19 PM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
Im personally not diggin the tips but it doesnt matter what I think. The air dam is necessary.
Old Nov 15, 2009 | 12:44 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
yeah, put the air dam back on, and if you rotate them 180* and point them down instead it will probably be ok
nice car BTW
Old Nov 15, 2009 | 06:03 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
thanks =] but if i point em down they might look dumb xP just gonna cut em off...cuz tthere not just clammped on..i welded them.
Old Nov 16, 2009 | 12:16 PM
if you like the 4 outlet style tips look for some borla exhaust tips. there's a guy around here with a 91/92 bird and it looks nice with em
Old Nov 17, 2009 | 01:37 PM
1Aauto's Avatar
Former Sponsor
That air dam is pretty important on these cars as there's no grille on the front of these cars to help cool the car at highway speeds.
Also keeping the motor cooler = more HP
Old Nov 17, 2009 | 09:26 PM
longer life span too
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
