White stuff under carpet
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I took my seat out again and peeked through the slit in the carpet and found some white chunks. They almost look like the solid chlorine pieces for the pool. what is it?
i have a picture if needed.
Re: White stuff under carpet
no, hardtop. it's more than just a little too. i can feel it packed in up near the front of the seat.
no it's not soft. they are hard pieces.
I'd pull the drivers side kick panel and door sill so you can lift the carpet and get a better look. There shouldn't be anything under the carpet except some jute padding, and maybe some tar paper sound deadener. I've had the carpet out of at least 15 thirdgens over the years and I've never seen anything that looked like that. It could be a build sheet, or assembly line garbage, or a shipment of narcotics from Columbia, you won't know until you look.
I can't tell other then in the area in the picture and that other area near the front.
drew, did any of yours have a slit in the carpet where I showed?
including the ones without power seats?
The wiring to the seat belt goes to the drivers side seat belt retractor... The cut in the passengers side is probably there for the cars with power lumbar. Either way, all that should be under the carpet is fluffy gray jute padding, and steel painted body color. I wouldn't be the least bit surprised if it were a petrified paper cup, or other garbage from the assembly line.
it's stiff and not soft at all, but it is a little brittle.
well it can't be rust repair. it wasn't repaired until i got under there.
I haven't gotten it up yet. that might be the side that has a screw I can't get out because it's rounded. it was too cold to work on it today.
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
... think you just found the PO's crack stash >.>
there is a rounded screw on that sill board so i can't get to under the rug.
Put just a little toothpaste on the tip of your screwdriver and turn slowly... You might also try using the next size larger screwdriver. A drill driver can work sometimes too. Beyond that, drill in the center with a 1/8" drill, then when the panel is out grab the shank with a vice grip and turn it out.
it's not sand as it didn't fall apart in my hand when i rubbed it. i actually should have a piece in my vacuum.
drew, I should try that soon. I am working on a header gasket currently.
pretty odd seam sealer not in a seam
really? I gave it a shot at least. 1 drill bit twisted in half, and the other must be dull although it doesn't look like it because i am getting nowhere with it.
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Damn, I read all 31 posts and I still didn't find out what it was!
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
My guess is it is the white paint from the factory mixed with a bit of corrosion under it making it start to peel/flake off.
yea I just got a couple new bits so I can try drilling soon.
I had pieces of the white stuff in my vacuum, but I vacuumed right over it so they weren't clean to show you. I did noticed it looked like they had little pores in it...little circles.
I've got another problem.
I drilled out the screw so now it separates. But, the screw that holds the sil place and kick panel together just turns. It came up some from the start, but won't come out anymore and it's starting to get rounded. this is weird
i did that and it didn't seem to do anything.
Just pull the kick panel up... That screw is a bit of a pain to get back in the hole, so usually it's just threaded into the carpet, or has the jute padding wrapped around it.
i forced it up real hard, but i'll try getting it out in the next few days.
Engine: 4++,350 & 305 CIs
your killn me smalls
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
i just read this whole thread and the suspense is killing me. AHHH! lol
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Engine: LB9
Car: 1983 Z/28
This thread has turned from finding out what the mystery substance is into a never-ending quest for sill plate removal. We might never know what it is!
I think we're hung up on kick panel removal, actually... So perhaps the easiest part to remove is keeping countless millions in suspense. LOL
ok then tell me how to remove it now that I've removed all the screws.
if all that's left is the seatbelt holder, the torx bolt won't budge for ****. ill try breaking it free again if that's it.
