beefing up the body/fram
Old Jan 16, 2010 | 11:51 PM
Knightly1's Avatar
I am helping my son rebuild his 86 camaro and i think we are gona have body twist issues. does anyone kno where to get kits to make them stronger or how to do it?
Knightly1
Old Jan 17, 2010 | 01:21 AM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
Re: beefing up the body/fram
Subframe connectors should help.
Old Jan 17, 2010 | 01:32 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
There are a few ways to due this. There are strut tower braces that tie top of front struts in engine bay (side to side twist), there is a wonder or steering brace bar (same as above but attaches front frame together side to side and was factory on some models). You can even get new front and rear frame assemblies. Stronger transmission crossmembers can help stengthen the chassis. and you could do a stronger upper rear panhard bar. Roll cages also offer good frame strength if you want to go that route. But the most common is sub-frame connectors. Some are pretty much to bars that run from front to back, some brands have a little better design. A lot of guys run different brands, I run UMI parts. here is the link for sub frame connectors http://www.umiperformance.com/catalo...roducts_id=127 here is the link for strut tower braces http://www.umiperformance.com/catalo...roducts_id=126 here is link for steering/wander bar brace http://www.umiperformance.com/catalo...roducts_id=125 They have more stuff on their site, so check them out.....hope that helps.
Old Jan 17, 2010 | 05:12 AM
Knightly1's Avatar
thanks thats just what the doctor ordered. we are seeing some twist damage before we rebuilt the motor. it a 355 with 9.5:1 pistons, and edelbrock performer heads, scat crank, and a 750 edelbrock performer series carb, a edelbrock performer intake, roller rockers and a bunch of other toys in it. so thanks a bunch for the help.
Knightly1
92projectcamaro
Dec 8, 2015 12:25 AM
Zell1luk
Sep 29, 2015 10:36 AM
75bike
Sep 20, 2015 09:37 PM
Mongoose462ci
Sep 16, 2015 11:46 PM
gta892000
Sep 16, 2015 12:37 AM
