92 Trans Am tail lights in a 92 Firebird
Old Feb 9, 2010 | 11:52 AM
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
I have a 1992 Firebird and was wondering if it's possible to swap trans-am tail lights into it without much moodification. I like the gird lights much better then the stock firebird ones.
Old Feb 9, 2010 | 12:16 PM
Drew's Avatar
Re: 92 Trans Am tail lights in a 92 Firebird
They'll bolt right in, the big thing is that most of the grid lights have the delamination problem where the grid pulls away from the lense. Also the wiring harness for the tail lights is different, you'll need the harness from the donor car. It probably won't plug in and work unless it's the correct year either.
Old Feb 9, 2010 | 02:28 PM
Car: 89 GTA
Engine: 5.7 TPI L98
Is there any other style of tail lights that would fit? Would you reccomend doing this switch in the first place? My tail lights are in perfect conditition now.
Old Feb 9, 2010 | 02:40 PM
Drew's Avatar
Any Firebird lights should bolt up just fine. I wouldn't recommend the grid style just because of how so many of them are falling apart. Even a nice set will probably go bad on a long enough time line. Nice ones aren't cheap either.
Old Feb 15, 2010 | 01:14 PM
Car: 89 GTA
Engine: 5.7 TPI L98
i'm not a big fan of the stock 92 firebird lights though either. Any idea of different thirdgen taillights to give a good look?
Old Feb 15, 2010 | 07:24 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Yes, it is very easy to do. You DON'T need to swap harnesses, but there is a little bit of rewiring required.
Here's a how to on what to do:
http://www.austinthirdgen.org/index.php?pid=37
Old Feb 16, 2010 | 06:23 AM
Car: 89 GTA
Engine: 5.7 TPI L98
So basically any thirdgen tail lights will fit into my bird without much of a problem if there's proper wiring?
Old Feb 16, 2010 | 06:26 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Thanks, that's a very helpful link!
Old Feb 16, 2010 | 04:14 PM
Drew's Avatar
The tail light harnesses are stupid-easy to swap... It's one connector, and a couple rubber grommets to change them. If you've got the donor car's harness, you could probably unplug your old harness and plug the new one in before a soldering iron would be hot enough to melt solder.
Old Feb 16, 2010 | 08:02 PM
edpontiac91's Avatar
Car: 1991 Formula 350, 2002 Grand Prix G
Engine: 350 with SLP & Edlebrock mods
Transmission: 4-speed automatic-700 R4
Axle/Gears: 10 bolt with 3:73
I have a set on my 1991 Formula showcar and it was a drop in except for the end socket. Your main problem is that have been out of production for quite some time now and good sets are hard to find. Most of them also have the PONTIAC letters worn off. If you want to see what they look like, just look up my album or in the "GMHT magazine pictures wanted" section under detailing and appearance.
Old Feb 17, 2010 | 11:48 AM
Car: 89 GTA
Engine: 5.7 TPI L98
basically your picture is exactly what i wanna do. i just dont know where i'll get the lights in good condition or the harness
Old Feb 17, 2010 | 12:06 PM
Stephen's Avatar
Car: 87 GTA
The lights alone wil cost you $250+ IF you can even find some.
People think they are gold. I much prefer the 87-90 TA/GTA 3-piece lights. Much cheaper & easier to find too.
Old Feb 17, 2010 | 03:42 PM
Whatever floats your boat, but the 1991-92 style was only for those years on the T/A and GTA and not that many were built to begin with, making them very hard to find in MINT shape and the last set I saw on eBay went for around $700.00.
Old Feb 17, 2010 | 04:55 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
just put some blackout covers on them. for $100 bucks will work just fine and will save u some frustration.
Old Feb 22, 2010 | 10:49 AM
Car: 89 GTA
Engine: 5.7 TPI L98
I definatley think I'd go with the 87-90 lights too. But would those require the same swap process?
Old Feb 22, 2010 | 10:55 AM
Stephen's Avatar
Car: 87 GTA
Wiring changes will depend on what car you start with & what year it is.
91/92 are closer to to the Camaro harnesses, 82-84 tail lights are different, 85-90 TA/GTA tail lights are different AND the 85-90 Firebird tail lights are different. And not just in appearances. I'm talking about bulbs, wiring & under the dash (for the 91/92s).
None of that is real hard to do though. Just a snip here & there on some & changing bulb sockets.
Old Feb 27, 2010 | 09:47 AM
Car: 89 GTA
Engine: 5.7 TPI L98
Best question yet, where can I find a pair of trans am tailights in good
condition for sorta cheap?
Old Aug 12, 2010 | 03:58 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
where can i get some for the 91-92 ta/gta tail lights
Old Mar 9, 2012 | 12:20 AM
KITT 84's Avatar
Car: 88 Trans Am = KITT
i just picked up a set of 91 tail lights for 160 bucks not the best shape but its better then nothing just trying to get the 91 convertible up and going
Old Mar 9, 2012 | 12:33 AM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
Always wished someone would trade my tail lights for a set of the 91-92 trans am tails :P In my dreams eh?
Old Mar 9, 2012 | 02:16 PM
KITT 84's Avatar
you should do a kitt conversion use the 82-85 lights?.. thats what i did to my 88 trans am =) took awhile to take the ground effects and all that stuff off the body ...all i need now are the bowling ball hubcaps for the outside and im done =)
but ya they r hard to find.. i need 2 take the set i have apart and see if i can fix the grid on it ...the way it looks..it just seprates from the lens..
Old Mar 9, 2012 | 04:55 PM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
I went with some 89 TA/GTA tail lights because i couldnt afford the 91-92. They are about the same w/o the huge price tag. I got mine for $30 on ebay. If i could find a decent set of 91-92 at a decent price id snag them. There were a few sets on ebay recently but people are either asking to much for ones in aweful shape or the nice ones are a couple hundred more than id spend. Some guy was e=selling a set with bad delamination for like $250 and said the price was fair (the delam was BAD). I even mad a reasonable offer and he got mad at me.
Old Mar 13, 2012 | 06:24 PM
KITT 84's Avatar
does anyone know off hand that has the 91/92 tail lights.. is the Pontiac in the center a decal?? mines missing it all i see is where it was
Old Mar 13, 2012 | 07:33 PM
Mudluver27's Avatar
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
post a pic of your taillights.
Old Mar 13, 2012 | 08:11 PM
KITT 84's Avatar
these aint my tail lights.... but its the same style 91/92 trans am/gta lights
Attached Thumbnails 92 Trans Am tail lights in a 92 Firebird-91_tail_lights.jpg
Old Mar 13, 2012 | 08:15 PM
Mudluver27's Avatar
Car: 1988 Firebird
love that style
Old Mar 13, 2012 | 08:17 PM
KITT 84's Avatar
ya had 2 get them for my rare 91 convertible
Old Aug 16, 2013 | 03:50 PM
tillyvick14's Avatar
Can anyone give specifics on what is needed to put 82-84 style trans am tail lights into a '91 firebird? As I understand it the 82-84 wiring harness is important to get.
Frozer!!!
Jan 19, 2024 04:55 PM
TheJoeY88
Dec 31, 2016 07:30 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
