so i just crashed my camaro
Car: 88 camaro z28
i came around a corner at about 9:00 tonight and accelerated hard and the pedal stuck. there was some gravel on the road and the car started to slide i got kinda scared because the pedal stuck and i over corrected and the car started to slide in the opposite direction. i seen the trees coming and my head thought hit the brakes but for some reason my foot diddnt slide over and it pushed the gas again i let right off but it was too late all i remember after that was hearing the window shatter and then i remember being out of the car watching two people drive by. then i realised the car was still running so i went and shut it off then called my parents and the cops i got a few pics with my phone that i will put up but i will get some better ones tomarrow when i go look at it at the shop it got towed too. but i think its totaled it hit on the pass side door and it was so pushed together i could barely open the center console to get my insurence and reg out of it. but i guess it could have been much worse atleast i diddnt get hurt at all my back is just a bit sore.
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: so i just crashed my camaro
I feel for ya man, cuz I have been down that road before. Be thankful that you are ok and remember that a car can always be resurrected in one way or another. Good luck.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Good to hear you're ok!!
Get your back checked--be safe!!
Sorry it happened.
Sorry it happened.
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
glad you're ok. You dont drive a Toyota so I dont think I believe the "sticking gas pedal" excuse lol
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Car: 88 camaro z28
thanks guys and Justin89Formy the funny thing about that is is the cop told me i shouldent be driving this kind of car and that i should buy a toyota! hahaha but on a more serious note either my pedal did stick or i have been having this issue where it will rev its self up for some reason and it will hold at that higher rev it normally diddnt do it unless i was letting it sit and warm up (i diddnt let it warm up before i left and i thing that may be why it happened)
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Thats weird. Is your car carbeurated? Because I had a similar problem in my 86 Z28 4 barrel. When the car was cold, the throttle, not the pedal, would get stuck at full. It freaked me out but I just threw it in neutral as soon as it kicked on high, popped the hood and un-stuck it. It only did it when it was first started up, and this problem only lasted about 2 months! Strange huh?
Anyways, glad youre ok. Sorry bout your car. It sux what happened tho. Hopefully its not totalled or there goes one more thirdgen. My 86 was totalled by some idiot in a honda who smashed it from behind while it was parked!!!!
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
yeah man glad you ok, I rolled a truck before and smashed into a tree. Was not fun 1 bit
sry bout ur maro
sry bout ur maro
Car: 88 camaro z28
no its tbi and when i bought the car i found out it had acctually been hit in the exact same spot and it was all pulled back out and repaired but i dont think its fixable this time the only thing that stoped it from going further was my subframe brace. the passanger seat was pushed in so tight i could barely open the center console to get my insurence and registration out
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
. and the carburetor thing happens to my uncle car it will be sitting there and just start reving idle-3k over and over. he has a nice exhaust so it sounds nice. when it does that he say "it must be that time of the month for her or she don't like ur car"
Car: 88 camaro z28
well i talked to the insurence company today and the good news is my insurence is only going to go up maby 400 dollars a year but the bad thing is i only had liability on it so im not getting any money for repairs and they arent covering my tow so i have to pay about 250.00 in total tow fees. but the good news is i may have found another car through my boces teacher apparently one of his friends has a 91-92 firebird formula that only needs a transmission the down side is its not a camaro lol and it has been sitting in a feild for a couple years but he only wants like 250 bucks for it but i feel for that amount of money for a thirdgen i cant go wrong.
also would it be possible to put my camaro front end onto the firebird? i know most parts on these cars are interchangeable if so what kind of work would be involved?
and pics would also be appreciated haha
Engine: 5.7 LSX
$250 for a formula isnt bad. trannys should be between $1200 and $3000 depending on what you want. It may need a new gas tank though! good luck!
Car: '87 IROC
You can change it over, but you need to put the entire front clip on from the camaro. Also there will be wiring issues since you are going from a two headlight system to a four. Good luck!
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Car: 88 camaro z28
i jush got home from checking it out i dont think its worth saving the entire car is squished together my sun roof wont close all the way any more and the entire quarterpanal is tweeked inwards the door and rocker and floor on the pass side is all junk ill add some pics. as for the firebird wouldny the tranny out of my car bolt up to it?
Car: 87 GTA
Good that you didn't have a passenger in the car, or the population would be down by 1.
Car: 88 camaro z28
ill probbably keep it a bird if i get it it was just an idea.
and stephen the thought of that scares me to death ecspeccially because normaly the only other person that rides with me is my girlfriend and i dont think i could live with myself if i hurt her or worse...
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Id say get the bird and drop the tranny from the maro in it. Should bolt right up. Also if you wanted to you can swap the front end from a maro onto the bird. I did it to my firebird but only because I wrecked the front end and needed to replace it and its all I had around at the time.
Car: 89 Iroc
Car: 87 Yellow Iroc-Z
Engine: 5.7 TPI
Axle/Gears: BW 9 bolt
Wow thats crappy. Hate to see another one go like that but that looks pretty tweeked.
If you ever gave any thought to parting it out , I would be interested in those black arm rests .
Car: 92 rs 25th anniverssary
Engine: 305 carbourated
Transmission: t-5 5 speed
im glad your alright man. if you cant fix her up then part it out with all the good parts im 99% sure you'll get your money out of it lol
Car: 1990 Chevrolet Camaro RS
Engine: V8 305
Transmission: Stock
Axle/Gears: Stock
It always hurts to see wrecks like this...I never like to see another third gen die. But the important thing is that you're alright and no one else was hurt, either. Sounds like you've got another third gen soon to replace it. Good luck with that! If you're sentimental about the totaled car, though and your parents don't mind storing some parts, perhaps salvage what you can from the totaled car and save it for restoring another Camaro down the road. That, or sell the parts.
OMG...this makes me grateful about my own split-second decision in my wreck last year, though. I had a momentary lapse of judgment when I watched a light change from green to yellow instead of the truck stopped not far in front of me. For a split second I considered putting my passenger side into a light pole and avoiding the truck for fear of hurting someone else and getting sued...looking at the pics of your damage, thank God I didn't choose the pole or I would have lost my car and possibly been seriously injured.
No injuries to anyone. The truck only had a little scratch on the tow hitch and a scuff on the bumper afterward. Turns out the truck was jacked up some, at JUST the right height so that it dead-centered the big steel part across the front of my car instead of going through my radiator. My car was technically totaled. The bumper/hood were destroyed, but everything under the hood survived and I drove away from it. It was totally restored and repainted about a month ago...I really should get some new photos up.
Anyway, good luck with the next third gen!
Car: 88 camaro z28
well i found out the firebird i was looking into sold a couple days ago sadly. and seeing how this car was my daily driver my mom is fighting with me about trying to get another chassis so im not sure if it is going to happen untill i return from my tech school next summer. i really dont want to part with the car it really has quite a bit of sentamental value to me and plus it has all brand new interior in it. the car also only has about 75000 miles on it and most of them around here in my price range have alot of miles on them. i think the car is going to end up getting stored untill i return and then i will find a roller and put my engine and interior ect. into it. unless i can find a cheap car or roller before i leave in june
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
i am also glad you came out ok,
sucks to hear the firebird sold
the Camaro front on a firebird has been done on here, the best one is the TransMaro/Cam-Am i think they called it, it looked really good in the end seeing as i love the back of the Firebird but i dont care for the front(unless its the older Flat nose GTA style)
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
well, I've only had one real collision in my camaro, but i wasn't in it at the time, some lady hit me and she was freaking out when i got there, i had some scratched paint, and she had a dented front end,yeah they are tanks. it happened in a parking lot and she insisted i take 20$ from her. I'm glad your ok, I would be pretty upset if it was my car, i love it to death. I spun out one time and didn't even wanna get out because i was worried what it would look like.I sat in the car for like 15 minutes just parked before i even got out. I would say if the motor isn't damaged, look on craigslist, find a cheap f-body around your year with a blown engine or "needs work" and just drop your original engine in it. same car, different clothes. as far as firebird/camaro, they are both awsome cars, that's why they are both in this thirdgen site.if i didn't have a camaro i would want a firebird. simple. 2 in 1? its the best of both worlds. Good luck, I'm glad you appreciate a great car
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
Like I said I did it to my car. I honestly like it better than the firebird front. I was never been fond of the firebird front end. I think the maro looks a lot better yet I like the firebird taillights.
Heres a couple pics of mines. I need to repaint the passenger door and hood. messed up a few spots.
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Duct Tape fixes everything
Car: 88 camaro z28
well guys i figured i would update this thread because im on the look out for a cheap rolling chassis the condition dosent matter because it is going to be a project car.i have a new dd now. im looking to spend somewhere around 5-600 bucks of my graduation money to get the roller or even if anyone knows of a whole car going cheap in my area i will do that too! im in ny and i dont really want to go out of state but neiboring states may be possible. thanks alot guys and if anyone knows of any thing please let me know!
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
There is a black 80s TA for sale sitting in a field near the road just off rt. 81 Mexico NY exit on rt. 104. Take the Mexico exit #34? rt 104 head west toward Mexico and
it is sitting just past rt. 11 & 104 intersection traffic light before you get to the village of
Mexico. Its on the south side of rt. 104..................
Will be heading that way tomorrow and will stop and get further details/phone #
for ya. Its been there for better than a month so it may be a jewel or it may be
junk! Won't know till I eyeball it up close..................
Car: 1992 firebird
Engine: V6
i have a 92 firebird it needs a front bump, hood and bumper support
so lady backed into the car and tried to run. it
s been sitting in my driveway for 3 weeks now has new tires on it and a rebuilt trans
Are those black stock GM mats? If so, I call 1st dibs Sorry about your misfortune
Engine: L03, LB9
Baltimore craigslist has one for $600, and i believe its OBO, its a v6 but since its gonna be a project for you it would be a decent start
Car: 88 camaro z28
i belive the mats came from classic industries (they were with the car when i got it) but im keeping all the interior for my new project.
i found one im rather interested in its a 86 camaro all dissasembled with all body work done and everything is primed it comes with 2 engines a 305 and a 2.6 an auto tranny and a t5 with all of the original interior and parts for 525 bucks and its only like 20 mins away
You are in NY so don't forget to look for rust. A couple of "field" cars were mentioned...been there done that and won't again. Get as much of a together car as you can locate/afford. Don't let your need over ride you good sense. If it is a roller the price is likely open for some discussion, most of them are casts off needing work if not cash. Remove all you can from yours before calling the hook to remove it. What you don't use can probably find a home with one of us thirgden lovers.
Car: 88 camaro z28
well guys i got a new one!! for 500 bucks details in here
https://www.thirdgen.org/forums/memb...ew-camaro.html
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Engine: L03, LB9
It goes up because liability pays for damages you cause to someone elses car, also insurance companies love to screw people over if your state requires you have insurance
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Engine: L03, LB9
Right he hit a tree i believe, so the insurace sees that as Making him a "higher risk" driver and raises rates, and if hes under 25 it really doesnt help.
Either way insurances companies will raise rates ober anything, its all
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm not all that convinced. The insurance company should only be able to increase the rate if he was issued a citation, or if they paid out a claim. Most states use a point grading system, and the threshold is > $500 damage.
I also don't know why a kid who only has liability would even call his insurance company if he hit something.
-- Joe
Engine: L03, LB9
-- Joe
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
