two spoilers on at same time?
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
check out this link http://www.crxsi.com/for-sale/cars/9...1268506073.htm i think that camaro has the rs and z28 spoiler attached on it i just wanted to know if i was seeing things or not..lol
Re: two spoilers on at same time?
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
I thought so lol. Now I see why its only 4k for the car
wonder what else is wrong..
wonder what else is wrong.. Supreme Member
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Haha >.>
Yea.... Previous owner before it came into the family then to me slapped it on and as you can see not very good. To top it off the hatch is not aligned properly. I have been wanting to take it off but then what to do with the drilled holes?
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Dude, you have to take that thing off of there! I would find some small caps or gromets or something, spray paint them green and stick them in there. That would be wayyyyyy better. I'd feel so stupid driving around with that.
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
*facepalm* this is almost as bad as one in my home town....had the regular spoiler and a big @ss ***** wing
I always wanted to take it off but I know something bad is awaiting for me under there.
Car: 1984 Camaro 'Vert
I think some people don't recognize that those lip spoilers are actually spoilers. I've seen the same thing on 4th gen Camaro RS's too. Just goes to show, that if it fits, someone will jam it on there.
Car: 87 GTA
I'd have pulled that wing off 5 minutes after buying it & be running around with duct tape patches covering the holes behind, much less have that car in my driveway for neighbors to see....And I don't talk to mine, much less are they good friends or anything!
What's your address? I'm on my way! I'm gonna rescue that poor car!
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
FTMFL.
YIKES!
Haha it has always been a plan to take it off but never got around to do it and haha no one here even knows that its not right and most say it looks good. I never liked it and the more I see it the more I want to take it off and get rid of it and keep RS style. Previous owner really did a job on the car and sadly its one of the better condition ones in my area.
Hey if you want to come over and help me out, bring some tools!
At first glance you can spot some minor things that are not right and can be fixed. The more I scan the car and find things I need to fix the more I want to slap the previous owner who abused this poor cam.
Are the mounts for the spoiler on the two center pillars, or on the edges? If its the center pillars, it looks like they are right in the middle of the racing stripes. Might make it easier to hide/repaint later.
Edges. If you look closer you can see their not even flush!
I tried giving the bolts a good twist and their freaking almost glued on there. Tomorrow is gonna be a bad day weather wise, So if i have the garage to myself Ill see what I can do. Im taking that thing off once and for all. Hopefully I can make some money of that and the stock airbag steering wheel.
Car: 87 GTA
Are the mounting bolts through the interior panel? Or does the panel cover the nuts, like it done with stock wings & spoilers?
Car: 89 Iroc Convertible
When I bought my 86 iroc back in 2004 it looked like the 1st picture minus the 91/92 bumper skin which was added by me.The 2nd picture is how it currently looks.The hatch was swapped from an exact same color 1986 sport coupe
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
i had the same as Carlos reg rs spoiler and high rise when i firs bought my 91. talk about identity crisis. mine came off as soon as i bought my car along with the nasty exhaust tips it came with. problem is you must cover the holes or water will leak in. i changed my entire hatch rather then weld in the holes, easier at least to me.
Car: 1987 GTA
Engine: 383 HSR
Transmission: 4l60e
guess seeing two spoilers is more common than I thought lol. I have a 92 wing but I have not put on due to filling the hole problem. What is the best way to fill it? Weld it or pay 200 bucks for a new hatch are my options at the moment. Anyone have a better idea? Re: two spoilers on at same time?
Wait till you go look at one of these cars for sale and they have a wing on it that is a wide as the rear of the car and mounts to the rear quarters. When you ask how they get the hatch open....they tell you the don't.
See this was what I was afraid of, Took the wing off. I got greeted by 3 drilled holes on each side. Car does look weird to me since well It wasnt really that of an eye sore but I still knew it wasnt right.
So any ideas to how to patch up these holes besides the usual welding patches in? Local junkyards never or rarely have Camaros there. Even then I am sure It will run me about 75-100 for the hatch.
Car: 84 frankenstein Z28
I replaced my spoiler with a high rise. Patched the holes with fiber glass on BOTH sides, being sure to slightly dimple in the holes to allow for the layer of fiber. Add some good body filler and the holes just disappear.
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Patch them with fiberglass/bondo and if that's the factory color (I'm assuming it is) just get your paint RPO code and buy the proper color of spray paint. I'd rush to get that fixed too hahaha.
Well its being garage kept atm. Here is a better picture of the damage the previous owner did.
I kinda knew what I had to do. I will have to order a small fiberglass kit and get it fixed asap. Like I said, damm does the car look weird. Got used of seeing the wing.
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Ouch, those are hideous.
The first posted car does have LT1 style tips that I like though
