i want to put my bird back on my hood
Old Apr 1, 2010 | 08:28 PM
diablood5's Avatar
Car: 1986 trans am
Engine: goodwrench 350, 4 bolt main.
first off.. i am new and i have to say this place is awesome. now.. i have a 86 trans am i am puting a 4" cowl hood on it this weekend and want to put the bird back on it but i am not sure what to do now that it has an extra 8 or so inches of hood to go over , i am afraid if i use a stock one it will look skinny. any ideas
Old Apr 2, 2010 | 07:27 AM
19transam86's Avatar
Car: 86 trans am
Engine: 5.0 305
Transmission: 5 speed
Re: i want to put my bird back on my hood
u can't put the bird over a cowl hood, it won't look right
Old Apr 4, 2010 | 10:37 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
you can get them from phoenix graphics.
what i would do is center it on top of the scoop and cut its wings flush with the sides of the scoop and put them on the hood strait below the center part.
i hope that made sense.
there's probably other ways to do it that's just how i would. its your car do what you want with it
Old Apr 4, 2010 | 11:14 PM
87bluebird's Avatar
Transmission: t56
another option you could do is have a custom bird made to stretch over the scoop.
Old Apr 6, 2010 | 08:57 PM
MrLeeks's Avatar
Car: 86 Trans Am, 2007 Chevy
Could you let me know where you got that hood from I have been trying to locate one and having lots of trouble. thanks its for a 3rd gen trans am right?
Old Apr 7, 2010 | 01:55 AM
87bluebird's Avatar
Transmission: t56
i don't know where diablood got his but you can get them on ebay from a seller called tamraz for $414
or from the seller ltdfiberglass for $410
Old Apr 7, 2010 | 06:46 PM
diablood5's Avatar
Car: 1986 trans am
its for my 86 . i got really lucky and found one on craigslist ... $60. and its a bolt on. the guy even gave me 2 hindges without the shocks. you can also look at summit racing . the have a lift off for around $350 or so..
Old Apr 7, 2010 | 06:50 PM
diablood5's Avatar
Car: 1986 trans am
when you say stretch... would i only have to change the wing size ?
Old Apr 7, 2010 | 08:08 PM
87bluebird's Avatar
Transmission: t56
just tell whoevers making it to make it 8 inches wider than normal this may increase your price a bit tho.
Old Apr 7, 2010 | 09:07 PM
diablood5's Avatar
Car: 1986 trans am
thanks . that is what i was thinking aswell. just looking for a second opinion. i am going to talk to a shop on sat to see what it is going to run me..
Old Apr 7, 2010 | 09:18 PM
diablood5's Avatar
Car: 1986 trans am
oh ... and be careful with some of the hoods on ebay. most of them are made really cheap and dont fit well. kinda thin on the fiberglass and warped , the tend to wana crack on you after having them an for a short time... i had to modify one a few months back so it would not crack at the hinges it also wanted to twist when opening it. its alot of $$$ to spend on a p.o.s. so just make sure you read all the feedback on them first
Old Apr 7, 2010 | 10:16 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Paint the bird on...i air brushed mine! you can search it to get the ideal- although mine is not in attempts to be the stock bird- more of a custom twist- but still
Old Apr 8, 2010 | 05:20 PM
diablood5's Avatar
Car: 1986 trans am
hey blacktop. do you have a pic of it....
Old Apr 8, 2010 | 06:37 PM
MrLeeks's Avatar
good information to know thanks
Old Apr 8, 2010 | 07:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well, Firefox crashed and i lost everything i just typed
any way, lets try again.
if you just stretch the entire image, the bird will distort, and will still look skinny when its wrapped over the cowl. What you may want to consider is just stretching the parts of the image that are on the cowl area so the image is still the stock width when installed, and the image looks right from straight on and on an angle.
here is a pic, left is stock, right has a small piece stretched in the middle of each wing.
hmm widened bird looks better too....
you should have to just measure the width of the top of the cowl, then the width and height of the raised side of the cowl. the measurement of the width and height of the side of the cowl is the piece that needs to be streached. Take the width of that piece from the original image and stretch it as wide and the cowl size is long. Then continue the image. That way the image is the same width after its installed, and still looks right.
I would have to see a good photochop to verify, but in my head it wiork
colton_carlson
Mar 8, 2019 12:21 PM
camaro11j
Sep 19, 2018 08:49 AM
justin57
Aug 20, 2015 07:05 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
