Aluminum Front Bumper Support Info
Old Jun 22, 2010 | 02:30 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hey all,
I just wanted to clear up some questions i have about these lightweight front bumper supports (AKA crash bars).
1) They are aluminum.. Lighter than steel ones found in 85+ camaros. These aluminum ones seem to be stock on 82-84 camaros. Is this true?
2) How much do they weigh / How much lighter are they compared to the steel ones?
3) I've read that they are part of the structural integrity of the front of the car. Aluminum is obviously weaker than steel, is there any truth to this? And if so, perhaps that is why GM chose to put steel rather than aluminum in the later years?
4) Do they actually make a difference in impact absorption compared to steel ones? I've 'read' that they are pretty much the same thing, and that he lighter aluminum one is just about as strong when we're talking about 'impact' damage.
5) When changing this, one must remove the whole front clip off the car, correct? That requires removing all the little plastic screws from the front of the car... I am worried that by removing everything, that all of these rare little pieces might break and i would not be able to re-assemble. Is it a huge job to do this? Sorry, i've just never done this before..
I've done pretty much all the other weight reductions possible, this just seems like a very good one considering it's on the very front of the car which is the BEST place to lighten up on these cars.
Thanks in advance!
-Marc
Old Jun 22, 2010 | 04:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Aluminum Front Bumper Support Info
1. true, dont think you could get them on later cars.
2. the one i have in the garage doesnt weight much at all, under 10 lbs easy
3. they are strucrual, they hold the frame together, keep them from spreading in an accident. Aluminum is weaker and will not hold up as well as steel.
4. same as #3. they have to be weaker, the one i have has a lot more openings in it (its from a camaro) vs my bird one which is solid and im sure weight a freaking ton.
5. the whole nose has to come off. everything. if the push in plastic clips break, just stop at the parts store and get new ones. they are available.
Old Jun 28, 2010 | 01:32 PM
RaisinHale's Avatar
Car: 85 IROC-Z
Engine: 355 SBC
Transmission: Powerglide
Axle/Gears: Moser 35 spline w/ 4.56 gears
I actually just removed the whole front "crash bar" assembly from my '85 about a month ago. The whole thing only weighed in at 28.5 lbs including the hardware (This is a steel one). I replaced it with a 3" wide piece of aluminum which now connects the chin spoiler to the radiator support (1.5 lbs).
Of course I would not suggest doing this to a street driven car.
Old Jun 28, 2010 | 04:01 PM
Woah, kinda cool! But, this looks like the left and right sides of the front are not even tied together anymore?
Old Jun 28, 2010 | 04:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
true, the fron end will flex a lot more now, but i guess its not a huge deal on a drag car that never sees the street. I would still like to see something there though, even if its just 2 plates and a piece of 1.75 dom connecting the frames together.
Old Jun 29, 2010 | 09:24 AM
If you were to put, say, the stock aluminum crash bar, would it be as strong (in terms of front end 'flex', not crash support) as a steel bar?
Old Aug 4, 2010 | 10:25 AM
i'm really looking into this as i may paint the car soon and the front bumper might just come off anyway, anyone know if front end strength (handling wise, not crash wise) will be compromised with an aluminum front bumper support??
Old Aug 6, 2010 | 07:11 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Not every 82-84 Car has them either. When you go out looking for one in the yards just bring a magnet with you. I've only found one out of all the cars i've found in the yards
Old Aug 7, 2010 | 08:05 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Another way to tell them apart is the support braces are bolted on the aluminum Vs welded on the steel bumper.The alumy version is also i little thicker.
Old Aug 7, 2010 | 08:19 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
are they interchangeable between camaro's and firebirds?
Old Aug 7, 2010 | 08:22 PM
Stephen's Avatar
Car: 87 GTA
Nope. Or my Camaro version would be on my GTA already. The Camaro piece is wider.
//<86TA>\\'s Avatar
Car: 86 Trans Am
AFAIK, the bumper itself is, but the honeycomb part is not, it would need to be swapped
Old Aug 7, 2010 | 08:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
really? wonder which one i have. i assume you could just trim the ends right?
Old Aug 7, 2010 | 08:31 PM
Stephen's Avatar
Car: 87 GTA
If cutting the ends would have worked, I woulda done that. I had the nose off anyways replacing it.
The mounts to the unibody didn't even line up & I had to get my car back together the same day. No time to modify stuff to work.
87bluebird's Avatar
Transmission: t56
whats different about the honey combs? i plan to use a camaro bumper on my bird would the honey comb still not work?
how much bigger are they?
Old Aug 10, 2010 | 11:37 AM
livewire's Avatar
Car: 1983 Z/28
the bumpers themselves are not the same. I had a aluminum bird one first that I tried to put on my camaro, bolted to the body fine but the bumper wouldnt even sit flush over it even with the honeycomb removed. it sticks farther out from the car than the camaro one. I ended up trading it straight up for a camaro one.
Old Aug 12, 2010 | 01:24 PM
I still am not sure about the structural rigidity of the aluminum bumpers... Why did GM put steel front bumpers instead of aluminum? I want to put the aluminum but i do road racing and autocross and stuff like that so I am wondering if the lighter weight is worth what the losses are
Old Aug 12, 2010 | 03:28 PM
Stephen's Avatar
Car: 87 GTA
Steel is definately going to be stronger for the same thickness & no doubt cheaper to make. Probably was for the cheaper reason though....
Old Aug 13, 2010 | 12:44 PM
livewire's Avatar
Car: 1983 Z/28
do you think you'll even notice a difference with rigidity? I highly doubt it. the weight loss is marginal anyways.
Old Aug 13, 2010 | 02:19 PM
yeah i read somewhere that it's roughly 9lbs lighter than the steel version, which is not bad since it's off the absolute front end of the car.. That, combined with relocating the battery to the rear and lighter weight 4th gen seats are my plans for now for weight reduction.
Old Mar 15, 2015 | 09:24 AM
direngrey's Avatar
I put my 84 se bird alum support on my 87 bird. It's alot lighter the steel one from the bird is heavy as poo
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
Wylecoyote08
Aug 22, 2015 01:58 AM
LittleFranks
Aug 20, 2015 03:55 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
