Leaky 1986 Trans am
Old Aug 7, 2010 | 10:05 PM
capellpm's Avatar
Leaky 1986 Trans am
Water is leaking into the floor of my trans am. Windshield was taken out and repaired all around, and new sealant and new window put back in. Can't understand where the water is getting in. Any ideas?
Old Aug 7, 2010 | 10:40 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Leaky 1986 Trans am
Where is it pooling up at?
Is it a t-top car?
Check your heater core.
Old Aug 8, 2010 | 11:51 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Try parking on a slight incline with the nose up and see what happens - that will let you know if it's the rear hatch seal. When level, or nose down, the rear hatch groove will fill with water right where it curves from vertical to the horizontal rear. If the hatch seal is allowing water in under it (between the seal and the car body), this water will run all the way up to front floorboards under the carpet.
Old Aug 9, 2010 | 10:31 PM
capellpm's Avatar
Thanks, I give that a try and see what happens.
Old Aug 9, 2010 | 10:33 PM
capellpm's Avatar
It is not a t-top and it pools under the floor mats in the front, mostly on the drivers side. I'll check the heater core as well as the other suggestions. Thanks, I'll let you know what I find out.
Pilotrick50
Sep 2, 2015 12:48 PM
michealleger
Aug 26, 2015 03:29 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
Catcher55
Aug 15, 2015 07:08 PM
