urethane reducer in enamel
Old Aug 19, 2010 | 04:38 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
more info coming
you dont need hardner
cures fast
Old Aug 26, 2010 | 09:28 AM
jamon8's Avatar
Engine: 350 tpi
Re: urethane reducer in enamel
I have left the two inner fenders that I painted outside in the grass 10 hours after painting and grass clipping are all over it
it gets wet in the morning and then the sun hits it all day
no one has anything to say about this
Old Aug 27, 2010 | 08:38 AM
MD83Z's Avatar
Are you saying that the reducer makes enamel flexable enough for painting plastic?
Old Aug 27, 2010 | 08:50 AM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
What?
Old Aug 27, 2010 | 11:12 AM
jamon8's Avatar
Engine: 350 tpi
I have not tried to paint it over plastic
but my firebird has enamel over plastic
just not with the urethane reducer
Old Aug 30, 2010 | 01:02 AM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Are you asking a question somewhere. You don't have to put hardner in enamel. People used enamel for years before hardners came along. But hardner made for enamel makes it a product that can be easier to work with in a production shop setting. Personally I'm always against mixing products or even brands. Paint companies do a good job of engineering paint to work and they stand behind their product. If you make your own magical mixture and have a problem down the road it's your problem.
Old Aug 30, 2010 | 01:09 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
I dont understand a bit of what u saying on ur first posts but
I AGREE 1000000000000000000% with 1piece@atime
don't know if u took chemistry but that what paint is. u start mixing chemicals and the reaction might not appear right away but keep a close eye in it (with safety goggles)lol
Old Aug 30, 2010 | 02:11 PM
jamon8's Avatar
Engine: 350 tpi
I am not the one who came up with it
simply a person who tried it and is formulating results
so far so good
Old Aug 30, 2010 | 06:33 PM
jamon8's Avatar
Engine: 350 tpi
here is why its important
if you clear over enamel(which yealds a glosseyer deaper shine) the enamel reducer and the urethane reducer could cause problems
if you could use urethane reducer (which so far I have seen to be true) then you could clear over it with no problems
instead of a 100 dollar gallon of base you could use a 50 dollar gallon of enamel
actually I am using it in implement paint which is made with soybeans
so before you start telling me I am wrong
give me some time to prove my theories
thank you
Old Aug 30, 2010 | 07:34 PM
Car: 86 T/A
Engine: 5.0 TPI
Reducers for either type of paint will evaporate over time with the majority of the evaporation happening rather quickly. Enamel takes much longer for the residual thinners or reducers to evaporate than does a catalyzed urethane paint. What you are doing is putting a urethane paint job over an enamel paint job. If I was painting a car that had enamel on it I would strip it down and do it with urethane. If you like nice things it's money well spent.
Old Aug 31, 2010 | 06:53 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
thank you
urethane is like $80-90 per gallon vs $50 for cheaper enamel. I'd rather use catalyzed urethane with appropriate hardener, reduced properly for the conditions.
urethane clear over it and then wet sand.
-- Joe
Old Aug 31, 2010 | 11:18 AM
jamon8's Avatar
Engine: 350 tpi
you know what you guys have all the answers
I am gonna stop posting things on thirdgen
things that are beyond you guys and your books and paint reps
you people are too close minded and I am not gonna be a part of that anymore
screw you guys
Old Aug 31, 2010 | 11:40 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
screw you guys
You need a better attitude.
Nobody said your idea was stupid. People responded with tech.
If you are leaving take care.
-- Joe
Old Aug 31, 2010 | 11:49 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
screw you guys
Being a painter in a bodyshop, I think I get the gist of what you're trying to say here. You're trying to keep the chemical families between enamel and urethane clear the same so when you clear over your enamel you dont get a nasty reaction, i.e. lifting or wrinkling? Regardless, you really need to be spot on with your mixtures everytime, and write them down, i.e. 4 parts enamel to 1 part urethane reducer, and never deviate. If it works, then do it up. Most of all, have fun, nobody would come up with anything new if it werent interesting and fun.
I mean if you screw it up, then it's a great excuse to by yourself an IR DA.
Old Aug 31, 2010 | 11:53 AM
jamon8's Avatar
Engine: 350 tpi
sorry joe
I just would appreciate if I was given the time to see if it works
I am in the experimental stages of my hypothesis(really it was not mine)
to be honest with you
if you believe in reverse phycology sp.
then I think you guys are actually motivating me
I just have to release some steam from time to time
I not really done with thirdgen
you guys helped me build the nicest car I have ever owned
for that I owe
just give me some time
those inner fenders are sitting in the elements right now
.....James
Old Aug 31, 2010 | 11:55 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
We know what he is saying. But I'm wondering why go through all of that? To save $40? That is why I said, I'd rather use a urethane base. It's not like it's 5 times more expensive.
Again, not staying it's a stupid idea. Just stating why I'm not doing that. I've used enamel's with just reducer on cheap fleet trucks like a long long time ago. I think black was $18 a gallon then.
-- Joe
Old Aug 31, 2010 | 12:06 PM
Car: 1992 RS 6spd
-- Joe
They still use cheap enamels on fleet rigs. And most places spray it through a Graco sprayer with the pickup tube right in the 5 gal. bucket haha. I did a couple frames on some Internationals, and the single stage was everywhere. I also agree with you though, he'll be happier with his results if he stays with all urethane IMHO. Use a good clear, I like Transtar Euro Classic 7024. 52% solids, easy to cut and buff to an incredible gloss.
Old Aug 31, 2010 | 08:28 PM
juanillox8's Avatar
Car: TOO MANY
sorry joe
for that I owe
.....James
just wanna say that u can do what ever u want we can't make u not do it.
when u post something here is because u wanna hear opinions specially from those who are in the trade whether u like it or not, at the end ur gonna do whatever pleases u.
but hey if it works for u and u are happy with ur results or findings Greeeat at the end thats all it matters, that u are happy
Old Aug 31, 2010 | 09:55 PM
Car: 86 T/A
Engine: 5.0 TPI
You asked!
Old Sep 1, 2010 | 10:40 AM
jamon8's Avatar
Engine: 350 tpi
spray something with enamel and then clear
then using the same color use all urethane
the enamel will outshine the urethane by miles
I did not ask
I just let u into my world
also the implement paint I use is 22 dollars a gallon
the clear well I buy pretty good clear
so those of you who want nothing to do with my experiment but to hate on it
the more haters I have the more I know I am on to something
Old Sep 1, 2010 | 10:47 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I did not ask
If you put clear over anything, the gloss will be that of the clear coat. It doesn't matter if you use $0.99 spray paint for your base color. .
Also, they make a base coat stabilizer additive for enamel paint to use them as an affordable base coat to clear over. The stabilizer will cause the enamel to flash out in 10-20 mins like a urethane base allowing the clear to be applied.
Why is this important ? The same reason you use the same brand chemicals in your paint job. The manufacturer formulated the thinners and chemicals to work together as a total system.
Textbook... certainly. Why ? Because when you use a like system the way it is supposed to be used, you achieve maximum adhesion as a paint system and the paint layers chemically bond to make the strongest paint system it can be .
Do you honestly think DuPont, PPG, BASF, etc have not fully researched the compatibility of chemicals to provide maximum results and durability plus, ease of application ?
It's great you think you neighbors, cousins, aunts, third removed in-law has developed some 'magic elixir' that PPG, DuPont, BASF, etc hasn't already tried and found to be unreliable for a long term (years, not a week in your backyard fending off the lawnmower clippings), stable paint system.
Old Sep 2, 2010 | 12:20 PM
jamon8's Avatar
Engine: 350 tpi
tell me more about the enamel stabalizer please
I am still learning
thank you for the support
Old Sep 2, 2010 | 02:28 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Let's get down to the heart of the problem in this thread. What's the story behind how you write your posts? Do you have something against using punctuation? Maybe if you used periods and question marks, along with a paragraph structure, people would know what you're saying and you'll get responses more to your liking. As it is, I don't know when you're making a statement or asking a question or when one thought ends and another begins.
I'll add a disclaimer. What I said wasn't a personal attack, it was meant to be honest feedback. I can see you were getting frustrated and taking it out on the site as a whole. However, I would expect you to have the same problem if you posted this on any other message board you join.
Old Sep 2, 2010 | 08:57 PM
Car: 86 T/A
Engine: 5.0 TPI
I'm a firm believer that two heads are better than one. Sometimes people get a one track mind and need someone else to help them view things differently. I thought you were asking us for feedback on your experiment.
Knowing what I know to be fact and with many years of training and knowledge learned in a bodyshop I think I know a thing or two. You don't have to agree with that statement.
I have to admit I haven't spent any time at all mixing, spraying or experimenting with soybean based tractor paint.
I applaud you for trying something new. I may not agree with your experiment or your testing procedure and I honestly believe your thinking is flawed, but fortunately we live in a world where we can do our own thing and we don't have to agree.
If you want to leave your inner fenders out in the yard for ten years or so then we can talk. I have a urethane paintjob on my T/A that was done in 1999. Bring them by ... we'll compare.
Old Sep 2, 2010 | 10:43 PM
deadbird's Avatar
Engine: TPI 305/ v6
I am still learning
I'm not being hard on you for trying new ideas but, when you discredit the years of R&D to make a paint system for some backyard mix... it's a little annoying.
http://www.pivco.net/index.php?main_...roducts_id=225
That is a local supplier of the product.
I've used it a number of times with great success.
I can appreciate trying to 'think outside of the box' but, paint is chemistry. It can be related to cooking. The wrong proportions or, ingrediants can lead to disaster.
Unlike cooking though, paint isn't based on a person to person taste, it is by the book of how the people that made it, works.
Choice of color is the only part that is left to personal taste...
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Pac J
May 17, 2020 10:44 AM
antman89iroc
36
Jan 31, 2016 08:42 AM
gord327
Oct 3, 2015 01:25 PM
dimented24x7
Sep 17, 2015 06:58 AM
