Camaro vs. Firebird?
Old Nov 11, 2010 | 02:02 AM
Dr. Phil's Avatar
Car: 1987 Pontiac Firebird GTA
Engine: 383
Axle/Gears: 3.42 10 Bolt
I dont want to start a flame war, but I just want to know a few things. Mainly which weighs less generally, a firebird or camaro if similiarly equipped? Also which has the less drag coefficent?
Right now I have an 87 gta trans am with a 383 stroker, t56, 4th gen rear end, subframes, etc. But im thinking about getting a camaro, paint/rustproof it and swap everything on my car over to it. My main gripe with firebirds is the iffy popup lights, you can never get them to line up perfectly and that bothers me. It also chips the paint on the edges!
Old Nov 11, 2010 | 08:40 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Re: Camaro vs. Firebird?
I dont think its that much of a difference I do believe the firebird is a bit heavier though.
btw don't you think that its ALOT of work to swap the whole car just for some headlight problems and paint chips?
Old Nov 11, 2010 | 03:10 PM
collin2201's Avatar
Car: 91 GTA / 68 Mustang Coupe
Engine: LB9 305 / 302
I wouldn't do it personally. You are wasting a perfectly good GTA for some trivial reasons.
And the Firebird is more aerodynamic.
Old Nov 11, 2010 | 05:10 PM
fadedirocz28's Avatar
Car: 1985 Camaro Iroc-Z
Engine: LB9
Just in case you need to go 150+ on the flats
Really though they're the same car. Some like the Camaro more because it looks meaner. Some prefer the Firebird for its, i don't know... refined look and slender curves? lol
Any weight savings between either one is going to be more dependent on the options than if its firebird or camaro, and its going to be a negligible difference between the 2 models.
Old Nov 14, 2010 | 02:56 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Dr. Phil....luv your show
Keep the TA and check out TDS for help with your light issue. They have some replacement parts you might find useful.
www.topdownsolutions.com
Old Nov 14, 2010 | 03:31 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Just have both like me and several other members here, LOL.
Firebirds is more aerodynamic, otherwise, they are nearly identical weight wise with similar equipment.
Old Nov 14, 2010 | 03:47 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
firebird is more aero
camaro has more possibilities iMo
one of each is good
Old Nov 14, 2010 | 04:12 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
It seems to me the '83-'84 Z/28 with the aluminum bumper, glass hood and Ac delete is probably the lightest one as long as your talking unmodified cars.
It would be easy to get your T/A alot lighter then that with some basic weight loss tricks.
I prefer the '91 and '92 Trans Ams the most but I like them all.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Linson
Aug 21, 2015 02:12 PM
antares57
Aug 6, 2015 07:47 AM
