Lift Points
Old Nov 22, 2010 | 04:09 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Lift Points
Searched with little luck. Can lift the rear end with no problem, not sure to lift from the front and apparently neither can someone else. Got my car back and found that the bottom of my fender is crushed inwards and also bowed out my fender.
If someone could show me where to lift the front, I'd appreciate it.
Old Nov 22, 2010 | 04:20 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: Lift Points
yeah the standard pinch welds on these cars are fairly useless (especially if its not rust free) because they always buckle. and it depends on the type of lift you use. when i do it, im using a lift where the lift arms swing in from the sides. and i have to jack up the front to set the lift arm so it clears the exhaust to get to the "body rail"
Old Nov 22, 2010 | 04:38 PM
Mr Froman's Avatar
Re: Lift Points
Okay, I'll see how that works because the lift I would use is the same type.
Old Nov 22, 2010 | 04:42 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: Lift Points
There is a sticky in suspension section called suspention 101. Has the jack point layed out there
Old Nov 22, 2010 | 04:51 PM
Twin_Turbo's Avatar
Re: Lift Points
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
PurelyPMD
May 5, 2016 04:57 PM
Jorlain
Oct 8, 2015 01:57 AM
anesthes
Sep 21, 2015 10:24 AM
Hill1513
Sep 19, 2015 04:15 PM
