Okay to jack by front sway bar?
Old Jan 7, 2011 | 02:00 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
Seems very thick and solid. Doesn't flex really either. I can't really get my jack to the cross member so I've been doing this.
Old Jan 7, 2011 | 02:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Okay to jack by front sway bar?
I wouldn't do or recommend it. BTW, there's a possibility that the bar on your car is hollow.
JamesC
Old Jan 7, 2011 | 02:38 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I wouldn't jack it by the bar itself, but you can jack up underneath the mounting point on the frame, although, I wouldn't do it all the time. If the jack doesn't fit, get one that does!
Old Jan 7, 2011 | 02:43 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
If you jack the bar you'll crush the bushing. It may take it a time or two if there's no choice but there's always another way.
Old Jan 7, 2011 | 03:35 PM
stackofire's Avatar
Car: 1991 Camaro Z/28 305
NOOOOOOOOOOO!!!!!!!!
Old Jan 7, 2011 | 03:43 PM
trocustoms's Avatar
Car: 1988 GTA Black on Black Hardtop
Engine: 383 miniram/ Ebl
Transmission: 700r4/Performabuilt/3000 Stall
Axle/Gears: 9 bolt / 3.27
Old Jan 7, 2011 | 04:00 PM
Stephen's Avatar
Car: 87 GTA
If you need the whole front end up? Buy/Make some ramps. Or jack 1 side up, put it on a jackstand, then jack the other side up & put it on a jackstand. If you have a stock Wonder Bar, don't jack it up by that either. It it stronger than the sway bar for jacking, but I still wouldn't do it.
You can jack up the whole rear end, but do it by the pumpkin, not the sway bar.
Old Jan 7, 2011 | 05:40 PM
JamesC's Avatar
I once straightened a stamped steel OE Wonderbar by sticking it between two blocks of wood, then putting a bit of my weight on it. I'd say it's certainly less substantial than, say, a solid 34mm sway bar. At any rate, as has been mentioned, neither is an appropriate jacking point.
JamesC
Old Jan 7, 2011 | 05:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You need 2 jacks with a low car often, one just to get the engine cradle up a few inches to jack there, then again when ya wanna take it out.
Old Jan 7, 2011 | 08:12 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
I always just up the front of my car by putting the jack under the K-member and then putting two jack stands under the A-frames.
Old Jan 7, 2011 | 08:13 PM
EvilCartman's Avatar
Car: '82 Z28
Drive onto some blocks of wood then put the jack under the front crossmember.
Old Jan 7, 2011 | 08:44 PM
Mr Froman's Avatar
Okay thanks for the responses, glad I asked! I wonder if doing it caused any damage.
Old Jan 7, 2011 | 08:45 PM
Stephen's Avatar
Car: 87 GTA
My solution at home, before lowering.....
I had to add another layer to the bottom, 6' long, to get the tires up on there to keep the nose from hitting anywhere. Yes, my ramps are "kinda heavy".
2" x 12" x various length from 18" to 6'.
Old Jan 7, 2011 | 08:49 PM
Mr Froman's Avatar
Yeah, simple and easy. Will do from now on. What exactly is a K member? Is that the crossmember?
Old Jan 7, 2011 | 08:52 PM
Car: 1991 Z28
The k member is the large bar behind the way bar that holds the engine.
Old Jan 7, 2011 | 10:02 PM
Mr Froman's Avatar
Thank you sir. Hope to get under my car this weekend to cure that front end popping, read it is possible I am missing bolts in the K member. Will also check the state of my sway bar and everything it connects to. Want to be certain I did not ruin anything.
Old Jan 7, 2011 | 10:12 PM
Stephen's Avatar
Car: 87 GTA
You are missing bolts in the k-member??? That is what holds your engine, which your transmission is attached to, it it supports the tranny too.
The coil springs press on it, so it supports/locates those.
The a-arms attach to it, so it supports those too.
What bolts are missing???
Old Jan 8, 2011 | 06:30 AM
JamesC's Avatar
I too have read that losing bolts there is a possibility. Checking can't be a bad idea (I did. All in place).
JamesC
Old Jan 8, 2011 | 10:00 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
took a k-member out of a 89? TA recently and one bolt on the passengerside was broken, the broken piece didnt fall completely out, it was stuck a little, but more or less it was "missing", its defiantly possible.
Old Jan 8, 2011 | 12:11 PM
Mr Froman's Avatar
https://www.thirdgen.org/forums/susp...our-front.html
Old Jan 8, 2011 | 02:49 PM
Car: 1991 Z28
My car has been making front end noises forever....thank you so much for posting that link.
Old Jan 9, 2011 | 06:55 PM
Mr Froman's Avatar
Sway bar looks fine. Jacked up by crossmember using wood blocks to get car up first. Off topic but which bolts am I looking for? Attached picture of what I saw underneath.
Old Jan 9, 2011 | 11:13 PM
Car: 1991 Z28
I was also wondering what bolts. I tightened all of the ones on the triangles, an then tightened the two A frame ones, and also tried to tighten two 18mm bolts by the A frame. Only 2 bolts on each of the triangles needed to be tightened. Went out and drove it and it still does it. I must have missed some but I can't see anymore.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
