Key won't turn in driver door?
Old Jan 21, 2011 | 07:30 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I've had no problem all day with the lock. Then I went to unlock it and I can't turn the key at all. Key goes in fine, but it's won't budge. I have to go in the passenger side and unlock it from the inside. What could be wrong?
Old Jan 21, 2011 | 07:35 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: Key won't turn in driver door?
frozen possibly mine dose that a lot. being that you can unlock it that means its not stuck, or maybe your key and driver side cylinder finally wore enough to not work.
Old Jan 21, 2011 | 07:39 PM
chevydrvr's Avatar
So what should I do? I don't want to force the key and break it or anything.
Old Jan 21, 2011 | 07:42 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
whats the temp. out there? any snow or rain?
Red 87 GTA's Avatar
heat it up some how and see if that works if it does not than bring your key to a locksmith and get the cylinder for your car and have it keyed and bring a lightly used key if you have one get a bunch of keys made hope this helps
Old Jan 21, 2011 | 07:45 PM
chevydrvr's Avatar
It's been cold all day long, but I've been locking it and unlocking it a few times today as I have to walked from my apartment to the parking lot back and forth. It's been working perfectly fine until it randomly decided to stop working. I'll try to heat it up somehow tomorrow.
Old Jan 21, 2011 | 07:49 PM
Red 87 GTA's Avatar
if it still dose not work see if you hold the key forcefully up so the teeth on the key dig in better if it works like that its just wear
Old Jan 21, 2011 | 07:56 PM
chevydrvr's Avatar
I'll give that a shot. I have all day to work on her tomorrow.
Old Jan 21, 2011 | 07:58 PM
Engine: 305TPI
Yah, that would be the best starting point is to get rid of the ice thats stuck in there (if there is any) if there is no convinent way of heating it up, you could always get an bottle/jug ice defroster and spray some on the lock cylinder, and then on the key and kinda wiggle the key around in there, not sure if that will work but its an idea, Good luck tho!
Old Jan 21, 2011 | 08:04 PM
chevydrvr's Avatar
Hopefully, with luck I'll wake up tomorrow morning and it'll work right! Hope the door doesn't get frozen shut again! I need to repair the hinges too (door sag/both doors) but the repair kits from TDS are expensive.
Old Jan 21, 2011 | 08:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
pour hot water on it, then drive to the store and buy spray lube.
shot it into the key hole and roll window down and shoot at it on the backside.
I get frozen out every winter.
First time it happened I got mad, I busted my hatch motor and pulled off my pass side door handle trying to get in, when hot water works much better.
Old Jan 21, 2011 | 08:16 PM
chevydrvr's Avatar
What do you mean spray it from the back side?
Old Jan 21, 2011 | 08:21 PM
Red 87 GTA's Avatar
roll the window down and spray from the gap in the back of the door that is made when rolling the window down.
Old Jan 21, 2011 | 08:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
ya stick the hose on the spray lube bettwen the rolled downed window and the felt and spray the back side of it and the linkage.....
chevydrvr's Avatar
OH, I got it. I'll pick up some lube when driving around.
Old Jan 21, 2011 | 08:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
shoot the door seals andor the places on the body behind the door where they touch.
They can get frozen to the car when you get a quick warm up then freeze and wont let it open, even when unlocked.
Old Jan 21, 2011 | 08:34 PM
chevydrvr's Avatar
Thanks for the help guys, first thing I do tomorrow is try some hot water and some wd-40 in the lock. If that doesn't work I'll get some lube and try that. I'll let you know what happens!
Old Jan 21, 2011 | 09:41 PM
ckelton's Avatar
Transmission: T-5 Manual
Dry Graphite!
Last longer, lubes better you can get some in an aerosol spray can.
Take a look at the key, my old key is worn out where the pass works fine, but drivers side is about the same.
If i lift up on the key and wiggle a little it turns, but gets irritating. Just a worn out key haha.
Sad thing is, its impossible to cut a new key out of a worn out key. However, your local locksmith shop can cut a new key out of the lock cylinder itself, and they do have to have the lock cylinder in hand, some can take it out of the car for you if you'd rather not mess with it.
One more thing, new lock cylinders are cheap enough to pick up at your local Oriellys 2 lock cylinders+2 keys. Downside, lock cylinder on the hatch wont match.
It all comes down to what the original equipment looks like, if its just worn out, then you know your answer.
Old Jan 22, 2011 | 09:54 AM
chevydrvr's Avatar
Good news! I just went out there and it worked perfectly, didn't have to wiggle or anything. Proably just some snow or ice got in there and froze it up. I sprayed some wd-40 inside the lock and on the backside just for extra measure.
Old Jan 23, 2011 | 01:47 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
If it does mess up again, I do know Napa Sells the door key mechanisms in black and chrome. I replaced mine a while back. They come with keys also
Derick15
Sep 17, 2016 05:28 PM
BlackTopKing
Aug 19, 2015 12:13 PM
chevyguy1999
Aug 16, 2015 08:49 PM
ZsTransAm
Aug 11, 2015 07:30 PM
BrianI
Aug 9, 2015 11:52 AM
