Trick to removing lower fender emblem?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am in the process of pulling the passenger side fender and I cannot remove the RS logo. Before I do anything drastic I wanted to hear if there were any tricks. When i peak behind the fender (cover removed) I can see that the factory installed these with self tapping sheet metal screws. However, after pealing off the top RS layer, I do not see the heads of the screws. How the heck did they put these on? Do I have to drill these out? I didn't expect these logos to be anchored like this.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Trick to removing lower fender emblem?
It's been awhile, but IIRC, the rocker emblem has two plastic pegs on the reverse that simply push into place. Again, IIRC, they can be seen from the back side. Under the emblem are two screws that help hold the ground effects in place.
JamesC
JamesC
Car: '90 RS
Engine: 377 LSX
This OEM as I am the second owner and the fender has never been off.
JamesC
Car: '90 RS
Engine: 377 LSX
Thats what I was afraid of. I am nervous prying them out with the fender and GFX being so fragile. Paybe I can cut/drill away the plastic from the emblem and use a small punch to drive out the pegs. Thanks James.
JamesC
Car: '90 RS
Engine: 377 LSX
I will take a closer look tonight when I get home and post some pictures if I don't succeed. I did remove all the small hardware from the GFX including the larger 13mm nuts underneight. I can see the pegs clearly when I stick my nose in the fender and peer in with a flashlight. The fender rocks and moves freely yet pivots/snags right at the point where the emblem is giving me the impression that this is the last connection. I might be able to pry it out with a thin blade without too much damage to anything, or like you said, push them out with something.
Car: '90 RS
Engine: 377 LSX
Well come to find out there are heads to the screws. The glue at the base of the plastic emblem had turned to concrete, likely fused with the GFX. I used a small drill to gently put some holes in the emblem. I was then able to pull it off in pieces with a pair of needle nose pliers. Voila! Fender came out. Pretty ugly process and I can't believe how much dirt was back there.
Mickeyruder
Sep 2, 2015 02:45 PM
Dialed_In
Aug 20, 2015 01:45 PM
