What do you think about this paint?
Old Feb 19, 2011 | 11:23 PM
native1031's Avatar
84 z28
Decided to start working on what needs attending and there are beginning signs of rust in rear wheel wells and theres cracing in the paint and little dings here and there so im going to repaint the car.
Its not my daily driver so I have time to do it.
What do you think of this basecoat and clear?
http://www.paintforcars.com/kits_sta...dyaplered.html
Ill probably be getting the primer from the site too unless someone has a better suggestion.
Old Feb 19, 2011 | 11:38 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Re: What do you think about this paint?
Seems cheap enough for a do it yourself type of person. Don't see why it wouldn't work
Old Feb 20, 2011 | 08:31 AM
bsporty's Avatar
Car: 85 Z28
Transmission: 5 speed
Have you checked out summit? they have a great paint line....if you do paint please dont use that little dust mask!! That is a particulate mask! You will need something with a charcoal filter for vapors.....check this one out its the same one I use daily!
http://www.google.com/products/catal...ed=0CD0Q8gIwAw#
Old Feb 20, 2011 | 11:20 AM
native1031's Avatar
I have two respirators. One that I had to pay the school to give me and one from my brother.
What primer should I go with?
I know I should use the same company as the base coat and clear but they dont have it. Ill try and find it elsewhere too
Old Feb 20, 2011 | 12:24 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
did you call them and ask them if they have a recomended primer since you are using thier paint that is what I would do. I like epoxy primer
Old Feb 20, 2011 | 12:54 PM
native1031's Avatar
Good idea haha
Old Feb 20, 2011 | 02:11 PM
CamaroChris83's Avatar
You'll need epoxy and high build primer. You need high build to spray on where you have bodywork and wet sand it down smooth, that way when its all painted and done you can't see the sand scratches where the bodywork is.
Old Feb 20, 2011 | 02:47 PM
native1031's Avatar
Thanks. The biggest dent is a little bigger then a quarter and its rite below the top curve of the FL fender. Just a couple other dings.
That is as long as nothing else has been done. the rear quarter was repainted at one time, so it will be interesting to see what happened. It wasnt on the carfax so yea
It goes high build primer then epoxy primer rite? and what about primer surfacer.
Hotrodboba400
Dec 10, 2019 07:07 PM
Drone358
Sep 21, 2015 08:54 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
