tail light restore?
Old Mar 3, 2011 | 04:35 PM
dans89's Avatar
Car: 85 z28
tail light restore?
Im looking for the best way to restore the tail lights on my 85 Z. There not too bad, just a few scratches. So what i was thinking was to sand them down a little bit and wax them. I also want to get the molded letters and numbers off of them. So my question is... would 220 grit sand paper be too rough? I have some laying around and i would like to use that if possible.
Old Mar 3, 2011 | 04:46 PM
DacMan's Avatar
Re: tail light restore?
Is the 220 you have wet sand paper? If not then don't even think of using is, it will gum up like crazy, 220 is too rough to begin with imo instead go to the store and buy an assortment pack of wet sandpaper, it should at a minimum have 320,600,1500 grit sheets. Start with 320 and sand the whole thing smooth, then move up to 600 then 1500 and then buy some polishing compound of some sort, i strongly recomend mothers mag polish, it's cheap and it works. That should take the 1500 grit scratches out is you take your time and really work at it (or if you have a buffer it shouldn't take long) then as a final coat i always like to use some nufinish to seal it all up. Don't waste your money on one of those cheap 30 dollar kits, they're such a joke.
Old Mar 3, 2011 | 04:50 PM
dans89's Avatar
Car: 85 z28
Cool, thanks for the info. I think im going to do that when i get a little bit of extra cash that i can play with. Im going to re paint the separation lines back to flat black too.
Old Mar 3, 2011 | 04:51 PM
GerryCat09's Avatar
Car: 1986 Trans Am WS6/1991 Firebird
Engine: 305 TPI/305 TBI
Transmission: 700R4 in both
220 grit would be way to rough. I probably wouldn't start with anything lower than 800 grit if there is really something that needs to be cleaned, like hazing. Best bet is to wet sand with 1000-1500 grit and buff them out. If there really isn't too much wrong with them though, don't go nuts, try just giving them a good buff and see how they look. When I was detailing I don't think we ever used anything lower than 1000 grit on headlights/tails.
Old Mar 3, 2011 | 05:01 PM
Scootermunch's Avatar
Car: 1989 Trans am GTA
Dans:
if you do it, throw in some before and after pics for us guys! i have been eyeballing mine lately, and was considering doing the same thing. i was just thinking of just only using 1,000 grit until my imperfections are gone, then use 1500, and polish.
Old Mar 3, 2011 | 05:09 PM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
theres numerous ways, as said above.
then after sanding theres this 3,2,1 polish kit you can buy online, i used it on my headlights and cleaned them up pretty nice.
you can use the headlight restorer for the taillights, Meguiars sells a kit with a pad that goes into a drill.
or if you have a bench buffer you can take the lights off and use that. i plan on doing that with my tail lights.
Old Mar 3, 2011 | 05:23 PM
dans89's Avatar
Car: 85 z28
Originally Posted by Scootermunch
Dans:
Will do. Like i said though there not too bad, just a few spots that are bugging me. And i really don't like the molded numbers/letters on them. I personally think they look tons better with out them.
Old Mar 3, 2011 | 05:26 PM
yeah, mine arent too bad also, there is a scuff on it (that is livable), and looks like some sort of overspray on the center phoenix (how blue paint got on it i dont know, there is no blue on my car anywhere haha). that will come off no prob. but mine are just dull looking and that is the biggest thing that bugs me.
i'll probably have time to get around to mine within the next few weeks, (after i acquire buffer) i'll post up some pics
Old Mar 3, 2011 | 05:34 PM
dans89's Avatar
Car: 85 z28
Same here. Gotta get the funds figured out, but when i do I'll post pics and a step-by-step.
Old Mar 3, 2011 | 06:38 PM
Hawk312's Avatar
Car: 2001 Firehawk, `86 Trans Am project
Engine: LS1 in both
Transmission: T56 six speed in both
I`ll just add my $.02...
I agree you are better starting higher, at like 1000 or so or whatever, unless your scratches are really bad. I mean, I only use 1000 to take out bad orange peel. I also use just a little bit of dish detergent in the water while sanding. If it were me, I would go up to at least 1500 before buffing. I like 3M rubbing compound after sanding, followed by meguires swirl and haze remover. I would also use Krylon semi-gloss black on the seperation lines...goes on nice, and is super cheap.
Old Mar 3, 2011 | 07:01 PM
dans89's Avatar
Car: 85 z28
Alright. Thanks for the info.
Old Mar 3, 2011 | 07:03 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
I've used the fine scratch remover/ headlight restorer on tail lights and it turns out fairly well. my before you buy a ton of sand paper
Old Mar 3, 2011 | 07:13 PM
Convoy25's Avatar
as far as sandpaper what i've used was
400:600:800;1000:1500:2000
Old Mar 3, 2011 | 07:30 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Scuff 'em up and clear 'em. Good as new.
Frozer!!!
Jan 19, 2024 04:55 PM
Jk_Under
Sep 2, 2015 10:59 PM
dibella989
Sep 1, 2015 04:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
