Removing the dash...
Old Mar 31, 2011 | 04:52 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Do I need to disassemble the dash to remove it, or will it come out in one piece after I remove the kick panels, dash pad and lower the steering? I need to get at the firewall and cowl drain...
Old Mar 31, 2011 | 04:58 PM
trans_x1985's Avatar
Car: 1985 pontiac transam WS6
Transmission: t-5 5 speed manual
Re: Removing the dash...
from my experence, you have to take it apart piece by piece....
Old Mar 31, 2011 | 06:28 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Nope... Pull the dash pad, remove the console, remove the lower panels in the foot wells, drop the steering column, pull the upper 5 bolts and the lower corner bolts, unplug the wiring connectors under the pass side and unbolt the one on the driver's side, and the whole thing comes out in 1 piece... Do you really think GM spent the extra time on the assembly lines putting the dash together INSIDE the car?
Old Apr 1, 2011 | 11:44 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Judging by how they had to go crying to The Annointed One for bale out money- YES, I do think they would be stupid enough to put the dash together INSIDE the car! LOL!
Old Apr 1, 2011 | 05:49 PM
Engine: 2.7L V6
Axle/Gears: 4.41
You would think so, but there's parts in and behind the actual plastic housing of the dash that just CANNOT be installed with the dash shell mounted in the car (HVAC ducting, wiring harness, others).
Old Apr 6, 2011 | 12:53 AM
Chris89FBForm's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI (For now?!?!)
Transmission: Auto-Stock
Axle/Gears: stock
taking apart the dash is much like...well imagine....you know what, it just simply sucks. and it doesn't help when perfeshinul mekanicz think they know how to wire...I blew 5 fuses before I figured out what kept tripping >_< twas a loose stereo harness wire that PO didn't take care of
Old Apr 6, 2011 | 01:24 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
its not the worst thing i've ever had to take out, but it does take a little while.
highly recommend a couple things - 1. take lots of pictures as you go so you can see where all the little pieces go back. 2. get lots of baggies and label the hardware for easy reinstall.
you can have the whole dash out in under and hour if you've got your tools handy (torx, 1/4" drive sockets, basic philips)
Old Apr 6, 2011 | 10:32 PM
Axle/Gears: stock
I had a nifty ratchet screwdriver w/ a bit socket for different bit tips aswell as a connector for sockets...made it bareable
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
