1988 firebird wireing
Old Apr 6, 2011 | 10:00 PM
6step's Avatar
Car: 1988 firebird
Engine: 2.8
Transmission: 5 speed
Axle/Gears: stock
my first time post, Anyone know where that small white wire gos just below the Hatch pull down motor ?
Old Apr 7, 2011 | 01:53 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: 1988 firebird wireing
Welcome to TGO! I think thats a ground...
Check out this site: www.the12volt.com
They have wiring for almost everything.
Old Apr 8, 2011 | 07:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
It's for rear wipers,I guess some of the Fire Birds had rear wipers.
Old Apr 9, 2011 | 12:42 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Never seen a white ground wire before - usually all grounds are black, or black with some color stripe. Here's wiring diags for most 3rd gens: http://www.austinthirdgen.org/index.php?pid=19
Old Apr 9, 2011 | 01:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
It was plugged into a black with orange stripe wire on late 89-early 91 models. It provides a switched ground to turn on and off the rear hatch light. If your 88 has the optional hatch light you'll have a manual switch to turn it on/off.
Lon
Old Apr 9, 2011 | 01:31 PM
Car: 1992 RS
Engine: Carbed 350
Oh yeah! I forgot about that white wire for the light.
Old Apr 9, 2011 | 04:13 PM
mantaguy's Avatar
Engine: 5.0 EFI
My GM shop manual shows only two white wires for the cargo area,one is the courtesy light ground and the other white one is the feed for rear wipers.You are talking about the white wire with a small black square plug on the end, right.
BRoss99
Aug 10, 2025 05:08 PM
jhawkeye
May 25, 2022 06:33 PM
stalkier
Aug 13, 2015 12:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
stalkier
Aug 7, 2015 04:49 AM
