Iroc-Z door stencil(to paint Iroc Z on the door)
Old Apr 14, 2011 | 03:13 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
My painter and I are trying to get a stencil that looks EXACTLY like the factory door decal(except reverse so we can paint it on the door).
Anyone make these?
Chris
Old Apr 14, 2011 | 08:16 PM
firehawk1988's Avatar
Car: Firebird Formula(1988 changed to 91
Engine: 355 TPI
Axle/Gears: 3.73(needs changed)
Re: Iroc-Z door stencil(to paint Iroc Z on the door)
You can check with a local sign and graphics shop. Sometimes they have certain common decal templates that they can make. If not you can get a hold of a decal or trace once off an existing car. They can make a reverse decal where the IROC is cut out and the rest is decal. I've seen this done for painting and sandblasting too.
Old Apr 14, 2011 | 09:51 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
I hope some place has them, I have been wanting to do the same thing to mine for about 6 months now. Don't want to buy decals again because I dont want to risk them peeling off again.
Old Apr 15, 2011 | 12:44 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Are you going to be able to paint them with the horizontal stripes. My IROC-Z decal is made from thin lines.If your doing the lines that's going to be awesome. Cant wait to see the end result.
Old Apr 15, 2011 | 08:32 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yes, I plan to do it EXACTLY like a factory decal, only reversed so we can paint it on. I asked him(the painter) about painting that section of the door, applying the decal, then painting the entire door. After that remove teh decal and clear the entire door. he stated that wouldn't work as well...
Old Jan 27, 2012 | 08:26 PM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
I'm also trying to get a template so I can make my decal IROC-Z sticker chrome. when I had my car painted the guy who was helping me decided he couldnt sleep one night and went into the garage and did some more prep work to the car.... sanded down my doors and removing the original IROC-Z decal in the process..... I really wanted to trace a template myself
Old Jan 28, 2012 | 11:02 AM
SylusMk2's Avatar
Car: 83 Berlinetta
Engine: 2.8
ive gone to vinyl shops arround here and they wont do it...they said they are copyrited
Old Feb 3, 2012 | 07:19 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
if this is still needed here is the graphics file
http://www.intergrated-it.com/camaro-6.eps
this is what it looks like
take it to a sign shop and ask them to cut it in paint mask material which you can get. then instead of pealing the outside off leaving the letters peal the letters leaving the mask. i can do it if there is a big enough need i have a 24 inch cutter
Attached Thumbnails Iroc-Z door stencil(to paint Iroc Z on the door)-mvc-031f.jpg
Old Feb 3, 2012 | 01:35 PM
User Error 87's Avatar
Car: 1987 Trans AM GTA
Engine: 5.7 TPI
Axle/Gears: 3.73 POSI
that looks pretty cool
Old Aug 13, 2012 | 06:34 PM
Pro-mo's Avatar
Car: 1988 IROC Z
This is exactly what I want to do as well.
Did you ever get it done?
And does anyone happen to know if there is a color code/name for the silver?
Out-Cast
Aug 23, 2015 06:33 AM
kah992
Aug 19, 2015 02:55 PM
BlackTopKing
Aug 19, 2015 12:13 PM
mustangman65_79
Aug 11, 2015 03:17 PM
