t top rust fix
Old Apr 30, 2011 | 03:12 PM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
t top rust fix
There is a little bit of rust on the black piece of the t bar on the inside of my car. I'm wondering if there is a way to take it off so I can sand it and paint it easier. I can take the three screws out on each one but after that I cant figure out how to take it out. I don't want to have to pull the weather stripping to get it off. Does anyone know how to take this piece off? Thanks
Old Apr 30, 2011 | 03:40 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: t top rust fix
Pics.would work. Their are six.bolts on the t top bar if you have rust might want to pull it off to check for.more rust . Their are Lot.of.treads on here for.t top rust repair I got a heard on here somewhere. That has.more.info and.pic that.might help
Old Apr 30, 2011 | 05:35 PM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: t top rust fix
Here's a pic of the t bar. It probable isn't that good though. Anyway I haven't been able to figure out how to get it off to sand n paint.
Attached Thumbnails t top rust fix-2011-04-30_15-54
Old Apr 30, 2011 | 06:04 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t top rust fix
If I remember correctly some of thebolts are hiding under the weather stripping just soak the bolts in penetrating oil first so they don't get stripped
Old May 1, 2011 | 09:07 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Re: t top rust fix
Hello, I hope you can see the yellow arrows I used to pin point the locations of the four screws that you have to remove to get the t-bar off. Not sure if you can see them with the weather stripping on. I removed my weather stripping because they previous owner put gobs of silicon all around the area. I was at the Carlisle car show yesterday and found some t-top weather stripping for $150 The yellow arrows point all 4 phillip screws that need to come out as well as the one's you can actually see. Good luck.
Stone
Old May 1, 2011 | 09:22 AM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: t top rust fix
So I do have to take the weather striping off to get to it. I didn't want to have to do that. I guess I'll just have to be careful with it and stick it back on.
Old May 1, 2011 | 09:49 AM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Re: t top rust fix
to simply answer your question - yes you do. The weather stripping goes right thru the t-top bar.. and you need to peel it back to get at the 4 hidden screws.. plus when you remove the bar, it will come off with it.. $150 for insure NO LEAKS is a small price to pay, but to each his own, right.. Stone
Old May 1, 2011 | 11:09 AM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: t top rust fix
It doesn't really leak at all that's the thing. I just want to take the little bit of rust off of it.
Old May 1, 2011 | 11:26 AM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: t top rust fix
Taking it off is well worth the piece of mind. When I did mine(which was not salvagable) I got one from a 91-92 car, sand blasted it, and hit it with about 3 coats of primer, three coats of base, and 3 coats of clear. I do NOT want to see that thing rust anytime soon.
Old May 1, 2011 | 12:19 PM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: t top rust fix
What all should I get to take the stripping off and put it back on? I know i.'ll need sand paper and black paint but what other things should I get?
Old May 1, 2011 | 12:49 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Re: t top rust fix
As long as your careful when you take the weather stripping off, other than what you stated you should only need a flat head screwdriver and some weatherstrip adhesive.
The screwdriver is to aid in removal and installation of the weatherstripping.
Old May 1, 2011 | 02:32 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Re: t top rust fix
My brother got a new ttop bbar and had it powdercoated since he got his buddy gave him a good deal on it
Old May 2, 2011 | 10:15 AM
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: t top rust fix
Well I got the t bar off and sanded down yesterday. Hopefully I can get it bondoed tonight on one of the metal seams that has some rust in it then paint it soon. I got some clear coat for it that is supposed to stop rust so it should help in the future.
Old May 4, 2011 | 01:38 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: t top rust fix
LOL, spacebar not working?
Old May 4, 2011 | 01:41 PM
navy02ws6's Avatar
Re: t top rust fix
There are some sort of caulking strips that the factory uses to re-seal this bar to the car. If not done properly, water will get in and the bar and body will start rusting again FAST.
I have yet to see a detailed drawing of where you're actually supposed to put the stuff though. Not exactly something you can just look up in a manual either.
Anyone successfully re-sealed one of these before that would care to help?
Old May 4, 2011 | 02:01 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: t top rust fix
GM manual on installing weatherstripping was posted in here:
https://www.thirdgen.org/forums/body...waterleak.html
Old May 4, 2011 | 04:05 PM
BIG BAD BIRD's Avatar
Car: 1985 PONTIAC TRANS-AM
Engine: 1969 350 290HP
Transmission: 700R-4
Re: t top rust fix
where do you buy the t-top bar????
Old May 4, 2011 | 04:22 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Re: t top rust fix
You can find them on ebay for around $80 I have a couple I plan to refinish then sale on here... Stone
Old May 4, 2011 | 05:43 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Re: t top rust fix
their are afew for sale on the boards ,the past couple of days check out the classified section
two-if-by-sea
Exterior Parts for Sale
Sep 13, 2015 06:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Amillionoh7
Aug 7, 2015 01:24 PM
3rdgenparts
Aug 6, 2015 09:03 AM
