Is this normal...
Old May 6, 2011 | 08:24 PM
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
Is this normal...
Tried to search but wasn't really sure what to search to get good results.
So I should mention that I haven't been driving the camaro as much since I got a old blazer to beat around, and i may be spoiled since I drive around in brand new lexus' at work all day.
but sometimes going over bumps I can feel it in my feet or in my seat. Just seems awkward to me for some reason. Ttop car, floors are in great shape, other specs in sig
I also had a clunk over hard bumps from what I assumed to be the door latch bouncing on the striker. Temp fix was wrapping a piece of gorilla tape around the striker, since it sticks well and is pretty thick. Has anyone else tried this? Seems to have improved it, Now most of the door rattles I think are coming from the window regulator, since the window seems to bounce around over bumps.
Thanks folks. btw, if anyone is selling an outdoor car cover please pm me, i'm looking for one.
Old May 6, 2011 | 08:26 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Is this normal...
no one is going to use ducktape on there cars on here.......
Old May 6, 2011 | 09:38 PM
Blackdog36's Avatar
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
evil, why post if you're not going to offer some advice? His car is pretty nice if you check out his cardomain. I'm sure other people have used duct tape to fix parts.
Cali, windows are know to cause noise problems over time. Do they make the noise when up or down? Might not be a simple diagnose. You might have to readjust your window. My windows seem somewhat loose too. I plan to try and fix it when I replace my regulator and door hinges. Not looking forward to it.
https://www.thirdgen.org/windowadjust
Old May 6, 2011 | 09:48 PM
Car: 1986 IROC-Z28
Temp fix like I said, Also a quick way for me to try and isolate and troubleshoot a problem. I now know what the problem is. I didn't hack anything, all i have to do is remove the tape. I'm saving a bunch of cash and scouring craigslist daily to find body parts so I can get it repainted this summer and fix all these issues correctly.
Cali, windows are know to cause noise problems over time. Do they make the noise when up or down? Might not be a simple diagnose. You might have to readjust your window. My windows seem somewhat lose too. I plan to try and fix it when I replace my regulator and door hinges. Not looking forward to it.
Only noise going up and down is the squeaking which I thought is the window sweeps. Recently when rolling the drivers side window up, sometimes the window will stick out instead of going up into the weatherstripping gap correctly. This creates a ton of wind noise more than normal, and I can actually see the gap across the whole length of the window. Actually every time I get in the car I have to crack the window down or it will catch on the weatherstripping and the door won't close, unless i slam it, putting lots of pressure on the glass which I fear will shatter it one day. When closing it from the outside I push in on the top of the window with one hand while pushing on the door with the other.
Old May 6, 2011 | 10:08 PM
Engine: L31 350
try replacing your pins, rollers, door hinges, that is whats causing your issue, over time these doors sag from being so heavy, i thought you were saying we should use duck tape on our doors if they rattle which is why i posted my comment earlier.
Old Feb 14, 2020 | 02:08 PM
ThirdGen84Coupe's Avatar
Car: 1985 Camaro IROC Lear Sieger
Transmission: 700R4 Automatic overdrive
disregard
Old Feb 17, 2020 | 05:46 PM
Billgluckman's Avatar
The sad thing is I think there’s several who would lol
chevydrvr
Feb 24, 2012 05:07 AM
bryanlz
Dec 10, 2008 06:00 PM
Thunderboy
Apr 16, 2004 05:41 PM
92 zzz28
Jan 15, 2003 10:00 PM
PurplePa$$ionz28
May 21, 2002 08:14 PM
