Body Rust, Should I give up the car?
Old Jun 15, 2011 | 05:25 PM
BlueDevil88's Avatar
Car: 1988 Firebird "Bertha"
Engine: 5.7 Liter TPI with minor mods
Well guys i've got an issue. I have an 88 Firebird. It has a good running 350tpi that uses not one drop of oil. The body on it has rust. Not a lot really, I've definitely seen worse cars. The other day I was out working on putting the front passenger seat in, and I thought since I had a piece of metal on me I would go around checking the rust spots to see how solid they are. All are pretty solid, except the passenger door. I lightly tapped it, and the ratchet handle went clean through.
It also has two holes in the wheel wells in the rear. T tops leak. The roof has surface rust. Under the carpet there is little rust. Just a few spots. That and the body underneath the door on the drivers side (side skirt?) is rusted through.
Would it just be worth my while to find a Base model or a formula (I like how they look without the ground effects) and swap in my 350?
I'll have me the money in about..oh 2 or 3 months to either grab a nice Formy or to get the body redone. I really have no attachment to this car.
Any thoughts are welcome. And yes, I know. This thread is useless without pics. I'll try to get some posted soon.
Old Jun 15, 2011 | 05:39 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Body Rust, Should I give up the car?
as you said very hard to say without pics, but the option of a roller to put your engine in is a good idea, but most rollers i see are pure junk, but then again you got a whole car that runs good to throw parts at a roller
Old Jun 15, 2011 | 05:43 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
I think you answered your own question: no attachment to the car. These cars are too common to spend a ton of time repairing rust in my opinion, unless it's a high option/low production # oddball model. Personally, I'd be on the lookout for a rust free car to swap your engine into.
Old Jun 15, 2011 | 05:53 PM
89RS_82Z's Avatar
where are you in charles county????
Old Jun 15, 2011 | 06:03 PM
Car: 2000 BMW M5
la plata
Old Jun 15, 2011 | 06:11 PM
89RS_82Z's Avatar
la plata
small world i was born there, i still go up there 2-3 times a year to see family, stay at the gradparents in waldorf/white plains
is there any junk yards up that way that have any 3rds in em, im always looking for parts to mail home when im on trips
Old Jun 15, 2011 | 06:13 PM
Car: 2000 BMW M5
I am from Connecticut, I have only lived out here for 3 years so I am not super familiar with all there is out here. From what I know though, no good junkyards. Brandywine bought out all the small yards and their prices are in many cases worse than new parts, I skip them altogether. I have to get everything on Ebay and craigslist.
Old Jun 15, 2011 | 07:50 PM
Thanks for the imput guys. I'm kind of leaning towards getting a car with a good body and just working from there. Every now and again a good car with a 2.8 or 3.1 pops up on craigslist.
Here are some pictures of my rust.
This is the hole in the door.
Old Jun 15, 2011 | 07:55 PM
Passenger Side Tire Hide Away
Passenger Side Wheel Well Top
Underneath Driver Side Door. Looks like it has been bondo'd or glassed.
Old Jun 15, 2011 | 08:18 PM
d2harris's Avatar
Car: 92 Camaro Z28
Engine: 5.7 350 TPI
I am restoing my car even though I have to get new floor pans and there is some surface rust on the roof and the bottom of my rear tire well. I love my Z and I don't see many 92 Z28 around anymore. I think if my car wasn't a 92 z I woudn't put as much money into, but I am attached to my car and coudn't stand to see it crushed or parted out.
Old Jun 16, 2011 | 10:38 AM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
The rust is fixable, but i think you may end up spending much more to fix the rust/body work/paint than to find a clean roller, or like you said, V6 car and swap your drivetrain into it. With no real attatchment to the car, thats what i would do.
Old Jun 16, 2011 | 10:51 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Does not look too bad I have repaired worse. I would say if you can do it so it your self probably not much more work than swapping into a roller.
Old Jun 16, 2011 | 01:30 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
If it were a Formula, GTA, or T/A, I'd say consider fixing it. But as this is a base model Firebird that will never be valuable and you apparently have no attachment to the car, I'd look for another car.
Old Jun 16, 2011 | 03:44 PM
Well guys, I think I am going to go to the route of finding a different car and swap my motor in, assuming I don't find a 350 car. I found more rust today. My drivers side strut tower, has a rust hole. Maybe the size of a half dollar and its almost all the way through. I figure by the time I get everything welded and patched I could have just spent the money and got me a car that either has no rust, or a lot less rust and no holes. lets go find my third bird!
Old Jun 16, 2011 | 03:51 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
yea better go get yourself another bird. im on my 4 firebird and finally have one with no rust. but yes i was in your shoes about 5 years ago. had to let my 87 formula go because of rusted holes in strut towers and holes around the car. like the guys stated above if it was not a base model it would be worth fixing. but my 87 formula i let go was alot worse then yours.
jhawkeye
May 25, 2022 06:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
Amillionoh7
Aug 7, 2015 01:24 PM
NBrehm
Aug 5, 2015 07:57 PM
