91-92 front spoiler sag fix?
Old Jun 22, 2011 | 10:07 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
I know this has been posted before atleast once. I only found one thread and it didn't show too much.
My front spoiler hascracked down each front corner (which I plan on repairing someday), but I also want to figure out how to fix tha sag.
It is sagging significantly in the middle, and it is pulled away fron the bumper cover on each side of teh grill opening. (I will take pics and post them later tomorrow). I want to figure outhow to keep this thing up!
Old Jun 29, 2011 | 12:53 PM
chevydrvr's Avatar
Re: 91-92 front spoiler sag fix?
Any ideas?
Old Jun 29, 2011 | 09:29 PM
Inpheksion's Avatar
Car: 1991 Z-28
Engine: 5.7L(350ci) TPI L98
Axle/Gears: G92
Hm, I was looking through some sites yesterday, and Classic Industries has replacement ones for not to expensive if it's the Z-28 front end, if you were planning on eventually repairing it completely, for 220 you could get a decent one now. And I don't have any experience in CI's Camaro parts, but my family has ordered quite a few large pieces in the past (Nova, Impala and Chevelle body panels and accessories) and have never had an issue with any of them.
http://www.classicindustries.com/cam...ts/c15292.html
Old Jun 30, 2011 | 03:10 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I've looked at mine and noticed that mine also shows a small gap between the GFX and the front fascia.
About 1/4" towards the centre, flush towards the sides however.
The only reason I can think of is that the baffle loses some of it's rigidity and allows for the spoiler to sag, whcih it gladly does due to the weight of the part.
Replacing the baffle should be the fix.
Before doing so however you could try disassembly of the complete front, fix any cracks in any of the parts, reassemble and see if it still sags as much.
If the car does not need to be 100% original, you can also reinforce the baffle.
Old Jun 30, 2011 | 06:14 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Take a peek to verify that all the fasteners, including those under the baffle, are in place. I'm assuming, of course, that my 85 is much the same as the later model years.
JamesC
Old Jun 30, 2011 | 08:27 PM
chevydrvr's Avatar
I'm confused as to where that pic is taken lol. But I'll check next time I get a chance.
Old Jul 2, 2011 | 02:01 PM
chevydrvr's Avatar
Here are some pics of my problem...
Attached Thumbnails 91-92 front spoiler sag fix?-p07-02-11_14.25.jpg   91-92 front spoiler sag fix?-p07-02-11_14.25-1   91-92 front spoiler sag fix?-p07-02-11_14.25-2
Old Jul 2, 2011 | 05:45 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Wow thats bad...Looks like someone parked it against a wall for a while.
Ive been thinking of getting some bars(flat iron or something) to cut to my own length. Then using the hole on the bottom of the radiator(were the air dam mounts) and then bolting them to the holes in the bottom of the front spoiler so that it pushes the front of the spoiler back out.
Mine hardly has any sag but i was gonna do it to strengthen it up some in case I run over a animal or something. But in your case i bet if would fix ur problem.
Old Jul 2, 2011 | 05:46 PM
chevydrvr's Avatar
That sounds like a great idea! Simple too. I may give that a try.
Old Jul 2, 2011 | 07:10 PM
JamesC's Avatar
Just curious. Did you verify that all the fasteners that hold the spoiler to the bumper are in place (I haven't counted but I suspect there are six or eight across the length).
JamesC
Old Jul 2, 2011 | 07:25 PM
chevydrvr's Avatar
I know a few are missing, but I don't think the ones that are would affect this. I am going to try to brace it like above and see how that helps.
Frozer!!!
Jan 19, 2024 04:55 PM
86IROC112
Apr 9, 2016 10:20 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
LilHot
Aug 19, 2015 10:02 AM
AkDrifted
Aug 17, 2015 07:45 PM
