Where to buy window guide rollers?
Old Jul 6, 2011 | 11:38 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I keep finding them assembled to studs for 2ndgen's but i haven't found any for thirdgens...
Just need the plastic roller like this with out the stud...
Old Jul 7, 2011 | 11:55 PM
FueledSoul's Avatar
Re: Where to buy window guide rollers?
bump
Old Jul 8, 2011 | 10:10 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I just took my window out last night, the one you pictured there looks like the one at the rear side of the window. I have a second gen door I can look at but I wasnt really ready to take it apart. I would give it a shot.
Old Jul 8, 2011 | 10:27 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Are they actually different across the GM lineup? That's an odd one.
I recently stumbled across this part for sale on an El Camino site, as it would work on my Monte Carlo. Perhaps they would also work on 3rd gens?
Old Jul 8, 2011 | 12:08 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I would say they are the same, but he seems to want JUST the roller and not the stud. Those rollers are usually really cheap and if I were in the need I would give them a chance from another car model/lineup.
I think the roller just pops off the stud pretty easy too, could always try that
Old Jul 8, 2011 | 12:30 PM
FueledSoul's Avatar
I pop all of them off. there on the regulators and windows theirs 4 per door.
I have piles of thirdgen books I.E factory service manuals , parts and illustration, factory explode sheets with part number/ name break downs but none of the 100+lbs pile of thirdgen books i own list a specific part number or name for that roller. Looks like i might have to do a lot of asking unless someone has already done the ground work ?
Old Jul 8, 2011 | 01:07 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
I know it sucks looking in there but have you gone through the group listings? I know there are some part numbers in there that are not in the illustrated portion of the part manual. I can do some looking when I get home too, I have the factory parts manual and I was thinking about getting new rollers too for my rebuild. I was just taking the door apart for easier moving, have 3 more to take apart they kind of suck sunce they are soooo damn heavy
Also I meant you could buy the 2nd gen ones and try popping the roller off the stud it comes with and try them
Old Jul 8, 2011 | 02:33 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I sold a bunch to Lon at Top Down Solutions a while ago. He should still have some available...
When I replaced mine, I had to lube it with lithium grease and use a c-clamp to press it on the stud. Worked like a charm and made a big difference to the window!
Old Jul 9, 2011 | 01:58 PM
FueledSoul's Avatar
I just looked for over an hour in the parts and illustration and the factory build production manual i found nothing. Yea i don't know what the deal there just plastic rollers im sure other GM cars have them too so i would have thought they wouldn't be so hard to find...
i wouldn't even bother for that price, and you end up wrecking the roller 9 times out of 10 anyways
Old Jul 9, 2011 | 02:00 PM
FueledSoul's Avatar
Yea iv looked there any haven't seen any. Where did you aquire the rollers from?
Old Jul 11, 2011 | 01:34 PM
FueledSoul's Avatar
contacted a few places, they said they have been discontinued... hard to believe since these are the same ones for 2ndgens minus the stud. need to find the manufacturer
Old Feb 8, 2018 | 10:20 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
https://www.facebook.com/thirdgensalvage/
Old Mar 9, 2018 | 11:51 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
bump
camaro71633
Sep 1, 2015 10:24 AM
evan555222
Aug 22, 2015 07:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
BrianI
Aug 9, 2015 11:52 AM
