Hood insulation?
Old Jul 10, 2011 | 12:38 PM
Krishan's Avatar
Car: 1991 Z28 Camaro
Engine: 5.0 305 TPI
Transmission: 4-spd Auto
Hood insulation?
I don't really know the name of this thing under the hood, but it's falling apart and I fear it'd get chopped up by the alternator when it spins. It's ripping apart and the plastic pieces holding it in place are of no use since they ripped off- somehow
Any ideas on how I can reattach it?
and should I also worry about asbestos from it o.0
Old Jul 10, 2011 | 12:46 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Hood insulation?
You can just pull it all off. I have on every one of my 3rd gens (steel or fiberglass hood) and never had a paint problem.
If you want to keep it & need new pins:
http://moderndaymuscle.com/82_92_camaro
Old Jul 10, 2011 | 12:51 PM
Krishan's Avatar
Engine: 5.0 305 TPI
The pins are still intact, but the liner itself has ripped away from it.
I'm getting paranoid on the asbestos issue...
Old Jul 10, 2011 | 12:55 PM
Car: GTA
I pulled my last one off bare handed, no problems. You can put on a pair of gloves & a long sleeve shirt if want to take extra precautions. Maybe throw on a dust mask since yours is falling apart so badly.
Old Jul 10, 2011 | 01:02 PM
Krishan's Avatar
Engine: 5.0 305 TPI
The hood won't look too pretty without it...as you can see. I think it's less effort to just keep it on the hood.
Guess I'd rather keep it on, idk how to put it back together though...suggestions?
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
There should be no asbestos in the they pretty much quit using that in the late 70's
Old Jul 10, 2011 | 01:41 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
where can we get new insulation?
Old Jul 10, 2011 | 06:05 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
ebay..i bought one for $35 plus shipping new...it was a few years back though.
then i got the clips and it really makes a nice look under the hood.
Old Jul 10, 2011 | 07:04 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Here's a couple of alternatives
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
Old Jul 10, 2011 | 09:04 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
the hood insulation question comes up often . it was not installed for heat protection . it was installed to muffle engine noise . i don't know about you , but if i have a strange engine noise . i want to know about it right away . then i can fix it before it becomes a major problem . i have removed it on all my 3rd gens. . just my thoughts . good luck .
Old Jul 10, 2011 | 09:20 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Id remove it and clean and prime/paint the bottom of the hood hell even rattle can. that hood insulation is so use less
Old Jul 13, 2011 | 06:39 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Yeah take that crap off and rattlecan the underside of the hood.
Old Jul 16, 2011 | 06:12 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Classic Industries.com.Just did mine $26.99 perfect fit,looks real clean.
Old Jul 16, 2011 | 06:58 AM
Engine: L31 350
pictures?
Old Jul 16, 2011 | 07:06 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I debated buying the universal sheet, cutting pieces and fitting them into the various triangles, to it doesn't quite hang down as intended, but still mostly in there...
Rafael
Old Jul 16, 2011 | 08:51 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
These liners are readily available on ebay. I bought one new for about 20 bucks. Best investment in under the hood appearance in my opinion.
Will
Old Jul 20, 2011 | 08:12 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Its a fire blanket in case of engine fire. No asbestos. Use auto interior trim removal tool to remove plastic clips. You will destroy plastic clips (they are reusable if not broken, but they will be old and brittle and will break) when removing. They are available new for cheap at auto parts stores. Buy new one and replace if you like safety over appearence, remove it if you like appearence over safety.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
