Has anyone bought this weatherstripping kit?
Old Jul 31, 2011 | 01:15 PM
cdoyle's Avatar
I want to replace all of my weatherstripping, and I found this kit
http://www.1aauto.com/1A/Weatherstri...01/242024/1984
I see the T-Top stuff is all GM which is good.
But the doors and hatch are not. I'm not sure what brand the 'aftermarket' stuff is. But I've read reviews on here, from people who bought various brands of aftermarket weatherstripping and I've seen fit and quality issues. Like on the door kits, the part where it screws in is not the same as OEM. Does anyone sell GM door kits?
Also with this kit, is this everything for the T-Tops?
Old Jul 31, 2011 | 07:39 PM
Camaros4Life's Avatar
Car: 84 Camaro
Engine: 350 punch out .060 to 360ci
Transmission: 700R4 worked
Axle/Gears: 410 Posi
Re: Has anyone bought this weatherstripping kit?
No but why would u pay $500+ for that kit when you can get it from camarocental.com for cheap.
http://www.camarocentral.com/product_p/wea-182.htm
Complete T-Top weatherstripping kit for $400 save yourself some cash
Old Jul 31, 2011 | 08:56 PM
cdoyle's Avatar
Are those GM T-Top kits? From what I read on here, especially on the T-Top weatherstripping you want the GM stuff to avoid issues later on.
Old Aug 1, 2011 | 08:01 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
there are additional pieces available (triangle seals, window sweeps, rain rails), but our kit noted above includes all the main seals you'd need for the car. And while our price may be higher than the other linked one, the t-top seals are OEM GM, not aftermarket (we do offer a lower cost kit with all aftermarket seals too). The doors and trunk are metro branded, but are high quality reproductions that should fit without any issue.
Old Aug 13, 2011 | 09:59 PM
cdoyle's Avatar
Hi Dan,
I'm going to go ahead and order the kit I linked to at the start.
Just one question, can't tell by the pic. But this kit includes the seal that I have pictured here? right?
Attached Thumbnails Has anyone bought this weatherstripping kit?-img_0769.jpg
Old Aug 13, 2011 | 10:08 PM
FryeDaddy's Avatar
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
The t top or you talking about the side weatherstrip? The side part is the t top weatherstripping (pretty big piece) also note if it says 8 or 6 piece t top weatherstripping.
Old Aug 13, 2011 | 10:24 PM
cdoyle's Avatar
The side piece, that seals the window when it's rolled up.
Here is pic of the kit
and description.
GM T-Top Roofrail Seals: Seal the perimeter of the T-Top, and the front/rear of the side glass to the body of the car.
GM T-Top Out Edge Seals: Seal the outer edges of the T-tops to the side glass.
Aftermarket Door Seals: Seal the back, bottom, and front of the doors to the body of the vehicle.
Aftermarket Hatch Seal: Seals the Hatch to the body of the vehicle.
Dan said earlier this kit includes all the major pieces, but I'm not sure I see that piece in that pic or description. I just want to make sure I get everything. and not realize later I'm missing something and have to reorder and make the shop wait on me that will be installing it.
Old Aug 14, 2011 | 12:56 AM
FryeDaddy's Avatar
and description.
Yes it is that piece on right side look like unside down "u", which is what I was saying earlier that is part of the big weatherstripping piece for t tops.
The other pieces he may talking about is like the triangle piece by the side mirrors, the hood, but the kit look like it does have most of the weatherstripping for the car.
Old Aug 14, 2011 | 03:45 AM
puma1552's Avatar
That's called the "Body Mount" T-top seal.
Don't skimp on weatherstripping, go genuine GM. It's all still available from GM, except the drip rails.
I just pieced together the whole shebang a couple months ago. Wasn't cheap, but I'll be glad I did it later.
I got:
--T-top seals
--T-top metal retainers (got the last two in the country, heh)
--T-Top Body Mount seals
--T-top drip rail (got one, the other I'm still looking for but it's the sole missing piece)
--Hatch seal
--Cowl seal
--Door seals upper (the long ones that go around 3 sides of the door)
--Door lower seals (extra seals along the bottom edge)
--Outer Door Felts
All of this can still be had either from GM or other companies selling it NOS. I will probably have to get 1A's drip rails though, because it doesn't look like I can get the other one anywhere, and I'd rather have a matching pair than one GM one and one aftermarket one.
Old Aug 14, 2011 | 09:20 AM
cdoyle's Avatar
What are these 2 pieces.
--T-Top Body Mount seals.
I got:
--T-top seals
--Hatch seal
--Cowl seal
--Outer Door Felts
Old Aug 14, 2011 | 10:02 AM
puma1552's Avatar
The "body mount" T-top seal is just that--it's the T-top seal that mounts to the body of the car, what the T-tops actually seal against (Part #7):
Part #30 is the Metal Retainer which holds the drip rail and the weatherstripping on the T-top itself together.
Old Aug 14, 2011 | 10:12 AM
cdoyle's Avatar
http://www.genmotorinfo.com/Picture....CC1)+-+1F12304
That website isn't loading for me, but thanks for the info.
So what's the difference between the body mount seals and the T-Top Seals?
Old Aug 14, 2011 | 10:45 AM
puma1552's Avatar
See above, I edited the image directly into the post.
EDIT: Part #29 in the diagram above would be the actual T-top seal.
Old Aug 14, 2011 | 10:57 AM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
We have original GM T-top and door seals available on our site. Here's a link if you're interested.
http://thirdgenranch.com/-strse-Weat...Categories.bok
The original GM pieces are MUCH better than any aftermarket pieces available.
Old Aug 17, 2011 | 08:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you have 2 seals that come in contact with the t-top. first is the body seal that mounts on the car and seals to the 3 sides of the t-top. the other one is the side seal; this seal attaches to the t-top and seals the t-top to the door glass.
hope that clears things up for ya
Old Aug 17, 2011 | 09:24 PM
Monster Pinck's Avatar
Car: 1982 Z28 Camaro
Engine: 362
Transmission: th350
Axle/Gears: 10bolt 3.42s
I got:
--T-top seals
--Hatch seal
--Cowl seal
--Outer Door Felts
What companies are selling it? Where did you get yours?
Should I paint the car before j put the weather strip kit on? ( sorry for the thread steal, didn't think a new thread was necessary)
Old Aug 17, 2011 | 10:19 PM
Former Sponsor
Car: Too many
We have all the GM weatherstripping available on our site and I don't think you'll find it at a better price anywhere else. It is best to replace it after your get your car painted. I'm not sure how soon you're planning on getting your car painted but you may want to think about ordering the weatherstrip as soon as you can afford to. More and more original GM pieces are being discontinued all the time so it's hard to say how much longer it may be around.
Old Aug 17, 2011 | 10:23 PM
puma1552's Avatar
I got most of mine from GM Parts Direct, otherwise Modern Day Muscle filled in the gaps. Thirdgen Ranch sells it, as does Hawk's.
Old Aug 23, 2011 | 10:53 AM
Engine: 362
Transmission: th350
I got:
--T-top seals
--Hatch seal
--Cowl seal
--Outer Door Felts
what were all the part numbers for the seals you purchased? im having a difficult time navigating through the GM.P.D. website. How much do you think you spent in total for all of your weather strip parts?
Old Sep 1, 2011 | 10:35 PM
Engine: 362
Transmission: th350
bump.
Old Sep 18, 2011 | 06:28 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
bump
Old Sep 19, 2011 | 10:49 PM
WHTrunner's Avatar
Car: 1986 Z28
+1 for the GM seals. My metros are coming apart at the seams after 15 months and need replacement. For all the work involved, the GM seals will be worth the extra bucks just because they won't fall apart. As an added bonus, they won't stick to your tops.
Old Sep 20, 2011 | 07:08 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Metro seals shouldn't be falling apart anywhere near that quickly and are covered for 10+ years against defects.
Old Sep 20, 2011 | 11:01 PM
puma1552's Avatar
Sorry for the late reply.
I put my VIN number into the GM Parts Direct website, but still had to do a lot of research. This was kind of a mess to figure out, and I can't guarantee compatibility outside of 1990, but my guess is most/all parts will be very similar, if not the same, particularly for later cars:
https://www.thirdgen.org/forums/hist...atibility.html
EDIT: GM Parts Giant website, not GM Parts Direct.
Old Sep 20, 2011 | 11:30 PM
Former Sponsor
Car: Too many
GM Parts Direct sells their weatherstrip very cheap but they make up for it with very high shipping prices. By the time you order two or more pieces from them it's very likely our prices will be cheaper.
Old Sep 25, 2011 | 11:57 PM
m16a2r's Avatar
Car: 1988 Pontiac GTA
Transmission: 700r?
ebay has a pair of outer window sweeps for less than 70 and free shipping
Old Sep 26, 2011 | 06:02 AM
KITT1983's Avatar
4 piece Window Weatherstrip Sweep Set
http://www.1aauto.com/1A/ExteriorTri...55/276748/1983
Old Sep 26, 2011 | 06:05 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
I would have liked to get a full kit for my car too. I got new GM roof rail seals a while ago and spent about 150. I went to a local pick and pull the other day and got two mint condition GM door seals off of a 92 RS for 5 bucks. The roof rail seals were perfect too, but with the factory sealant they are a bitch to get off without damage, so i left them. Good parts are to be had for cheap if you get out and look. I like new too, but sometimes a corner cut here and there is good. I cant tell you how many times ive bought items off ebay, only to find out that a trip to a local salvage yard, that allows you to get the parts yourself, could be had for 1/4 or less than the purchased price from those sources.
No ill intent is directed at anyone in this post.
hectre13
Dec 11, 2023 08:14 AM
italiano67
Dec 11, 2016 09:21 AM
86IROC112
Sep 7, 2015 01:37 PM
crazynights
Aug 21, 2015 06:53 AM
johanlindgren
Aug 16, 2015 12:16 AM
