Too much rust?
Old Aug 29, 2011 | 08:25 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Too much rust?
I just acquired an 86 camaro. I knew the floorpans were rusty when I bought it. I just removed the interior carpet and found the exact rust spots.
Driver side front where the left foot sets, there is about a small hole about 3 inches wide. The driver side rear... is bad. where the back passenger would sit there feet... its a hole about the 1 square foot.. and the rust climbs up under the rear seat and there is a hole there also. The passenger side only has a tiny hole and just surface rust..
damn t-tops. Is this even repiarable?
Old Aug 29, 2011 | 08:29 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: Too much rust?
Is it repairable? Yes.
Is it economically repairable? It depends on the sentimental value of the car, or how much you are willing to shell out to put new Pans in it.
The driver side could probably be ground down, and patched. We did that with my friends car and it worked well. Stopped the rust dead, and fixed the tiny hole in the floor.
But if faced with what you describe for the passenger rear footwell, I don't know. If I saw it on my car I'd just part it out and start with something else.
Old Aug 29, 2011 | 08:51 PM
Engine: 383 Stroker
Transmission: t-56
Re: Too much rust?
I have never welded before and know little about body work.
As a temporary fix I was looking at some cheap fixes.
Some people suggested cutting the rust out and weld some steel in place and then put undercoasting over it.
Another method would be to still cut the rust away, but instead use fiberglass and then put undercoating/seam sealer over that. How would these work?
Old Aug 29, 2011 | 08:59 PM
Re: Too much rust?
We used a wire wheel to get clean metal, primed it. then used sheet metal and sheers along with some body glue. When it dried we coated it all. Worked fine.
The only real way is ofcourse to replace the pans, but we coudn't weld and they were small holes in non-structural spots.
Old Sep 4, 2011 | 01:52 AM
spdmetl's Avatar
Re: Too much rust?
Put this car on a hoist and have somebody experienced look it over
Old Sep 4, 2011 | 09:52 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Too much rust?
He's right. No sense in stressing yourself out over this. I would take it a step further and get more than one opinion as well. As oppossed to a dealership, most auto shop estimates - from my experience - are free.
Old Sep 5, 2011 | 01:00 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Re: Too much rust?
Body glue..? What kind? What brand name? Where do you go to buy it ? I have 4 quater size rust holes in both my front pans and really looking to do what you did to "patch" them up. Any help is appreciated ..
Stone
Old Sep 5, 2011 | 10:44 AM
Re: Too much rust?
Stone
Don't remember, it wasn't my car so I didn't pay for it. Its basically the same stuff they used in the factory.
Old Sep 5, 2011 | 01:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Too much rust?
There is no such thing as to much rust, if the car means something to you.
Do SFC first though, then hack away at floors at will.
https://www.thirdgen.org/forums/susp...rs-solved.html
Old Sep 5, 2011 | 01:26 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: Too much rust?
over half my floor was rusted out to repair it i took 18 guage steel shaped it to the basic shape of the floor then i welded it in when the metal work was done i went over the floor withe 24 ounce fiberglass the welding i did wasnt to hard it was just put little welds every couple of inches all together for all the materials used it costed me 90
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
