body twist
Old Sep 29, 2011 | 05:59 PM
86iroclover's Avatar
Car: 91 rs
Transmission: 5 speed
Axle/Gears: 308
body twist
how do i keep my car from twisting when i put a new motor in it. should be around 400hp if i can do what i want (if the wife lets me lol)
Old Sep 29, 2011 | 07:25 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: body twist
weld in subframe connectors will help.
Old Sep 29, 2011 | 08:29 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
Re: body twist
do some chassis reinforcing but realistically a stock thirdgen will handle that fine without help they are very strong uni-bodies as long as there is no trans brake or you dont dump the clutch and hook up.
My 84 T/A has about 420ish hp no frame reinforcement and its a t-top so you should be just fine
Old Sep 29, 2011 | 08:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: body twist
Unibody cars will flex. Many stock coupes, for exampe, will have stress cracks behind the drip rails (mine does). I'd strongly suggest SFC's.
JamesC
Old Sep 30, 2011 | 03:41 PM
Derth Deboblo's Avatar
Car: '91 Firebird (blown apart)
Engine: *cough*BOAT ANCHOR*cough*
Transmission: Slushbox
Re: body twist
As said before in so many other threads, weld in SFC's should be one of your first mods if you're going to build a higher HP motor then stock.
Old Oct 2, 2011 | 09:11 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Re: body twist
JamesC
Hmm, so that's what that is? Mine has 1" cracks on both sides.
Old Oct 2, 2011 | 05:59 PM
Guest
Guest
Posts: n/a
Re: body twist
mine has no cracks...
Old Oct 3, 2011 | 07:55 PM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Re: body twist
1991 RS--Does your car have T-Tops? If its a hardtop you should be fine without the SFC's...
Old Oct 3, 2011 | 09:09 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: body twist
Hard top stress crack, no sub frames, old combo was about 450hp. Its hard to tell from the picture but it has about a 3" by 3" buckle in the quarter next to the crack (both sides). Sub frames are on the to-do list.
Old Oct 3, 2011 | 09:35 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: body twist
chassis flex is the thirdgens worst fault IMO it's not
just the passenger area that flexes,the whole front
structure of these things also flexes and "matchboxes"
mightily-noticed this with mine the first time i drove it
with the hood off and was shocked to notice the radiator
support area jiggling independent of the cowl area
Shortly after noticing this(in 1994,100,000 mi)added
stout SFCS,extra x-member under fan area,cowl struts,
a few gussets, and added extra welds to certain areas.
this did add some weight alright,but cured the flex
problem 95% and it has stayed tight for over 17 yrs
since i did this (over 245,000 mi. now)
BTW when i bought my z28 in 1990 with 86,000 mi it was actually pretty tight yet,but after driving it through
a couple winters and thrashing on it the flex started to
creep in....
A rigid thirdgen drives so much nicer than a stock,flexi
one does
Old Oct 5, 2011 | 04:11 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: body twist
Get some subframe connectors, and a strut tower brace. Maybe a stronger torque arm as well. These will also improve handling, which is a nice addition.
Old Oct 6, 2011 | 12:56 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
Re: body twist
hard top here
mine also has about 1" behind the drip edge passenger side.
Old Oct 6, 2011 | 08:06 PM
JimRockford's Avatar
Re: body twist
Just curious,do the fourth gens flex too?
The second generations honestly don't seem any more rigid than the third gens,especially the t-top cars.
Old Oct 6, 2011 | 10:41 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Re: body twist
I've never driven a 4th gen,but GM did put some effort
into designing the 4th gen to be more rigid as the 3rd
gen flex problem was well known by the time GM started
to design the 4th gen.'92 model 3rd gens had "strucural
adhesive"applied to welded seams to help them be more
rigid than earlier thirds though i don't know if this made
much improvement over the long run or not.
I did notice some chassis flex with my '69 camaro,but it
was not as obtrusive as my '82 was before i fixed the
flex problem.Also my '69 was much less stiffly sprung
and has far smaller sway bars as well as lighter weight
than my '82
I have a porsche 928 and '68 roadrunner that also have
some chassis flex problems that need corrected
The mopar has front end shake and "matchboxing"
at least as bad as a stock thirdgen When i bought the
porsche i thought i had at least gotten a car that would
have a rigid chassis...Wrong!
Old Oct 7, 2011 | 09:51 AM
Re: body twist
I'm kind of surprised a Porsche would have noticeable body flex too,although I believe the 911 Targas were know for that.
I know the new Mustang convertibles flex like crazy too and have leak issues and second gen Trans ams especially those with t-tops flex as much as third gens.
Old Oct 13, 2011 | 05:51 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: body twist
my 83 z28 (t-tops) had 400+ hp with nitrous and the chassis was all kinds of twisted and it was way to expensive to fix and now I am a huge advocate for subframe connectors.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
