Removing my cars "sun burned" look? Tips?
Old Nov 2, 2011 | 03:33 PM
J0hn_J0hn08's Avatar
Car: 1986 Iroc-Z
Engine: 355
I need some tips on the best way of removing my cars peeling clearcoat lines.
It is only on my rear quarter panels but it looks pretty bad. I tried using 1500 sand paper but it ended up leaving a white spot on the area i used it in.
I dont want to remove all of the clearcoat i just basically want to blend it in without standing out as much.
Heres what im talking about
Anybody have any ideas?
Old Nov 2, 2011 | 03:44 PM
82tarecaro's Avatar
Re: Removing my cars "sun burned" look? Tips?
I have heard once the clearcoat peels, a repaint is necessary.
Old Nov 2, 2011 | 03:45 PM
Car: 1986 Iroc-Z
Engine: 355
Lol obviously, im looking for a temp solution.
Old Nov 2, 2011 | 03:51 PM
82tarecaro's Avatar
OK then - good luck with that.
Old Nov 2, 2011 | 04:00 PM
Guest
Guest
Posts: n/a
....sand it down and prime it....
Old Nov 2, 2011 | 04:04 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
I'd wet sand it carefully, so as you don't cut through the color coat. 1000 -2000 grit, go carefully. Then polish. Then seal with the automotive detailing sealant of your choice.
Old Nov 2, 2011 | 04:05 PM
Car: 1986 Iroc-Z
Engine: 355
@patin..wouldnt that leave a patch and make things worse? Im not trying to get a paint job here just want to blend it in lol.
Old Nov 2, 2011 | 04:09 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
for temp. then wet sand the quarter tell there is a dulling of the color, and you get it smooth, tape the edges with hard edge tape, clean well with wax & grease remover, mask off and spray with rattle can clear. you can get some good quality products, which will make the deference.
chazman's Avatar
Axle/Gears: BW 3.45
Originally Posted by J0hn_J0hn08
...wouldnt that leave a patch and make things worse? Im not trying to get a paint job here just want to blend it in lol.
After you wet sand it, (WET not dry), it's gonna look whitish, flat and just plain not nice. That's when you polish it - either by hand or if you have an orbital - it'll shine right up. Just don't sand or buff through the color. Go slow.
Old Nov 2, 2011 | 04:10 PM
Car: 1986 Iroc-Z
Engine: 355
Thanks chaz, ima give that a shot. I just wanted to know the best way to go about it i know it wont be perfect, just didnt want to start scratching everything up.
Old Nov 2, 2011 | 04:13 PM
Car: 1986 Iroc-Z
Engine: 355
Sorry about that chaz that post was meant for patin.
I do have an orbital along with Polishing and rubbing compound.
Should i bother using the rubbing compound first?
Old Nov 2, 2011 | 04:16 PM
chazman's Avatar
Axle/Gears: BW 3.45
I'd wet sand first. And when you buff, start with the LEAST agressive polish.
Car: 1986 Iroc-Z
Engine: 355
@flydoc
I have some rattle can clear, once the clear is on should i do anything to it or just spray it and leave it? Would wet sanding it shine it up any?
Old Nov 3, 2011 | 12:16 AM
puma1552's Avatar
Leave it alone, you're only making more work for yourself for later.
Old Nov 3, 2011 | 12:35 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I was able to do my bumper, the side's are a lot harder on the metal. I used wet sand lightly, then buffed with a buffer, wax, buff, wet sand, wax, buff. A lot of work but mine turned out nice. Where I cant get the peeling is on the above the tire area. I use a good meguiars polish, keeps it shinny and covers it some. I was told not to use spray clear coat. It discolors really very fast. The paint under clear coat can be polished with a buffer very nicely. You have to be very careful.
Old Nov 3, 2011 | 07:28 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
There is no temporary solution that looks good. Get it repainted.
Old Nov 3, 2011 | 08:58 AM
chazman's Avatar
Axle/Gears: BW 3.45
Just as a reference, this:
Became this:
http://www.autopia.org/forum/click-b...l-details.html
The way I look at it is, if you think it'll need a repaint anyway, then it's worth a shot.
Old Nov 3, 2011 | 09:04 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Shiny oxidation?
Old Nov 3, 2011 | 09:35 AM
chazman's Avatar
Axle/Gears: BW 3.45
Well, you're never going to make clear coat failure look perfect, but you can vastly improve it's looks.
Old Nov 3, 2011 | 09:43 AM
chazman's Avatar
Axle/Gears: BW 3.45
Here is a single stage paint '82 Trans Am. How many folks here would have pulled out the primer rattlecan instead of saving this paint?
http://www.autopia.org/forum/click-b...ior-shine.html
Old Nov 3, 2011 | 09:46 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Single stage is different than BC/CC. You can get away with it easier(to a certain extent) with single stage.
Old Nov 3, 2011 | 10:07 AM
chazman's Avatar
Axle/Gears: BW 3.45
That's why I noted that it was single stage. The point being that I so often see folks here taking a faded and weather beaten finish and instead of restoring it, they'll reach for the can of primer or Rustoleum.
The OP has a complete cc failure. Nothing will make that look perfect beyond a repaint. But there is plenty that he can do to improve it's looks.
Old Nov 3, 2011 | 10:23 AM
Car: 1986 Iroc-Z
Engine: 355
@ chaz
Wow i just saw the thread you linked. That is really good.
But unfortunately I dont have anywhere near the tools u used. Today im taking this on. I know a lot of you argue that the only solution is a repaint but as of now a repaint isnt within my budget and it looks like crap as it is so i dont have much to lose.
Ive decided not to spray anything on, im not familiar with rattle can clear coat, i do know that wet sanding and polishing can give it a clear coat finish but the polish wears off after a while.
Pretty much the only things i have to work with are
Turtlewax polishing compound
3m rubbing compound
3m 1500 sand paper
And a turtle wax orbital buffer.
I want to avoid spraying anything but i do have some perfect match GM victory red touch up paint if needed.
Old Nov 3, 2011 | 10:45 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
if the clear coat is just discolored and oxidized, it can buff out really good, if its peeling off, its a different story. and the turtle wax compounds are crap. they only thing turtle wax is good for, is their wax.
Old Nov 3, 2011 | 11:21 AM
Car: 1986 Iroc-Z
Engine: 355
Yeah its peeling pretty bad. To the point where i can just
scratch it off. Its the outline its leaving thats pissing me off.
Old Nov 3, 2011 | 11:26 AM
travis401's Avatar
Car: 91 Camaro RS
Not much you can do for peeling clear except to lay on more clear. If its just the qp doing it, take it to a shop and get a quote on fixing it. Shouldnt be more than a couple hundred to repair. If you plan on getting it repainted soon you can do a temp fix with some rattle can clear.
Youll just have to keep wet sanding untill you can feather down the edge then spray on the new clear, then wet sand and buff it. It wont last for long but its better than peeling clear.
Old Nov 3, 2011 | 11:32 AM
chazman's Avatar
Axle/Gears: BW 3.45
@ chaz
3m rubbing compound
3m 1500 sand paper
Don't give me too much credit, that wasn't my work. Those were pros who posted on another website I frequent.
Wetsand with the 1500, buff with the 3M and then you have to seal it with something. Even a dirt cheap sealant like NuFinish is better than nothing. It needs to be sealed because the exposed color coat will oxidize very quicky if you don't.
Old Nov 4, 2011 | 12:49 AM
puma1552's Avatar
I remember that first thread on autopia, though I hadn't seen that 'bird...thanks for sharing. It's absolutely amazing what can be done with a rotary in the hands of someone with years of experience.
Old Nov 4, 2011 | 02:32 AM
Engine: MPFI
That's what I'm talking about! A buffer and some compound. Thats what I did to mine and you will be amazed at how nice it looks! Great job
Old Nov 4, 2011 | 12:01 PM
Car: 1986 Iroc-Z
Engine: 355
Started last night on this, i like how its coming out but its taking me a very long time. i can still see some of the clear coat lines so im gonna continue sanding it today. It already looks a lot better.
At one point i left some spots where i sanded off too much, but i managed to save it with some touch up paint.
As far as the sealant goes, how does that work exactly? is it a spray on? rub on? Ive never used one before.
Thanks for the help so far guys.
Old Nov 4, 2011 | 02:41 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Maybe I should try this on my fender... You polished the base coat therea nd it blended with the clearcoat that well?
Old Nov 4, 2011 | 04:39 PM
Car: 1986 Iroc-Z
Engine: 355
I wet sanded, then used rubbing compound followed by polishing compound. It blends okay but it depends on how well u wet sand i used 1000 grit followed by 1500, thinking i need to go rougher to really get the lines completely off.
Old Nov 4, 2011 | 05:06 PM
travis401's Avatar
Car: 91 Camaro RS
the only down side to polishing the base coat is it wont stay shiny long. its meant to have a clear coat over it for protection and to get the shine.
Old Nov 4, 2011 | 09:11 PM
chazman's Avatar
Axle/Gears: BW 3.45
Goes on and off like wax.
Old Nov 4, 2011 | 10:22 PM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Started last night on this, i like how its coming out but its taking me a very long time. i can still see some of the clear coat lines so I'm gonna continue sanding it today. It already looks a lot better.
as good as it is going.. looking at you picks, I would try the polish & sealant..
if your going to do the clear coat, put several coats on with recommended flash time between, then 1000 wet, buff and polish.
Old Nov 4, 2011 | 10:54 PM
puma1552's Avatar
I'll give credit where it's due, you made a nice improvement in the appearance, OP.
Old Nov 4, 2011 | 11:00 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Very impressive! If you do think about putting clear over that, you'll have to get every ounce of polish off first so it will stick.
Old Nov 5, 2011 | 10:02 AM
travis401's Avatar
Car: 91 Camaro RS
wax and grease remover off the shelf at the auto parts store will take care of that. just give it a few good scrubs to make sure you get it all before laying down the clear.
1992 Trans Am
May 10, 2023 07:19 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 8, 2015 07:09 PM
Poncho92
Aug 7, 2015 08:15 PM
