Rear Glass Compatibilty
Old Nov 4, 2011 | 08:01 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Can I take the glass section of a rear hatch for a third gen, say a Camaro, and replace it in a hatch for a Firebird. Would this work? They seem similar.
Old Nov 4, 2011 | 08:12 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Rear Glass Compatibilty
All 82-92 Camaros & Firebirds hatches are interchangeable.
Old Nov 4, 2011 | 08:26 PM
antares57's Avatar
Thanks. Appreciate the quick response.
Old Nov 4, 2011 | 08:28 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
If you're looking at the hatch for the sister car, they will either have the spoiler holes in the wrong places or none at all. Keep that in mind.
Old Nov 4, 2011 | 08:59 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I don't know about the Camaro's but my GTA's mounting bolts for the aerospoiler were in the deck lid and not the glass.
Old Nov 5, 2011 | 12:36 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
the glass is physically the same demensions across the years(verts not included), the rear hatch lid has different holes or no holes depending on application. also the glass had different options for the 3rd brake light and rear defroster.
Old Nov 5, 2011 | 08:56 PM
Engine: LB9, LS1
That's what i meant. Obviously the spoilers aren't bolted to the glass.
Anyways, i can't see why you would try and put the same decklid on different glass. It's more work than it's worth.
Old Nov 5, 2011 | 09:18 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
If he wanted to "clean up" the third brake light by moving it inside (91-92), he could find the glass and switch the decklid. One reason to switch the decklid.
Old Nov 6, 2011 | 09:17 AM
travis401's Avatar
Car: 91 Camaro RS
the rear deck lid is only held on to the glass with a few nuts and some adheasive, its not hard to take off at all. welding up and cutting new holes in the existing deck lid, then doing the body work to make sure its all straight. then getting it to match the existing paint sounds like a lot more work to me than switching out the hatch and matching the paint.
Street Lethal
Apr 30, 2019 12:14 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
AkDrifted
Aug 17, 2015 07:45 PM
BrianI
Aug 9, 2015 11:52 AM
