Where do I begin for exterior work. Kinda confused
Car: 1985 Camaro Iroc
Engine: 350 tpi
So I bought my 1985 Camaro Iroc z28 a few months ago. Just now getting around to doing body work. (still have mechanical issues to work out).
Anyhow..
My right quarter panel needs to be replaced. Its dented/scratched you name it. So how do I go about fixing this?
I pretty much just buy a right quarter panel...get it painted.....then get it bolted/welded (w'e it is I don't know actually)
Sounds silly that I make this thread, seems kinda like common sense, but I'm looking at budget. What would be the cheapest way to go about doing this. All the body shops around my area wanna take a arm and a leg.
Anyhow..
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: Where do I begin for exterior work. Kinda confused
if you mean the rear quarter panel[not the front fender which bolts on]it has to be welded on and then bodyworked and then painted.try searching youtube.
Engine: 350 tpi
Yes I mean the right rear quarter panel.
And damn that looks like its gonna cost a pretty penny. Also need to get the front fender replaced (though it doesn't look horrible, its just scratched up real bad).
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
any pics of the quarter? more damage can be repaired unless its really bad. replacing the entire quarter will be expensive.
Engine: 350 tpi
Engine: 350 tpi
Some guy told me today he could fix it for $400....doesn't sound like a bad idea but I wanna keep looking.
Car: 1985 Sport Coupe
Engine: 3800 Series II Turbo
Transmission: 4th-gen WC T5
Axle/Gears: 3.27 BW Limited
Talk to people and get a line on a good local small-time bodyman. That can be worked out with a slide-hammer and then skimmed but the big shops will want your left n** to do it. Get a guy working on the side out of his shop and cut him a deal.
Just my two cents.
Just my two cents.
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
No need to replace the quarter....just some metal work and some mud work.
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Is that rot on the wheel well lip? hard to tell in the pic but it looks like rust
Car: 1987 camaro sc
Engine: lg4 305
the quarter doesnt need to be replaced get a cheap slide hammer and a tub of bondo cost of 35 dollars and a coupe hours of work
The quarter is borderline IMO. The huge dent on the body line tells me to replace it, but a *good* bodyman *may* be able to reconstruct the body line. However, those deep creases tell me a different story.
I think it could be pretty presentable without being replaced, but to truly get it perfect it would need to be replaced. There is a NOS quarter panel for sale in the classifieds here currently (though I can't recall what side off-hand).
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
agreed, any one who suggests using a "tub" of bondo on a few dents doesn't know the first thing about body work. itll take a lot more than a slide hammer and bondo to fix that correctly.
since that huge dent actually runs right through the middle of the body line, and it looks like the quarter is actually punctured through near the wheel well opening, its gonna take a pretty experienced body man to salvage that quarter. not impossible, but not something a beginner is gonna get right. the dent is going to have to be pulled out, the puncture welded up, the creases hammered out, then many many hours of hammer and dolley work to shrink the metal back into shape. then more work to reconstruct the body line straight.
Car: 90 RS
Engine: 5.0 TBI
I disagree.. Thats not terrible at all, and if he does it correctly and more importantly takes his time it should come out just fine. It doesn't have any gaping rust holes and plus he can get at the fender from the inside because that's where the space saver spare tire goes. If you think that ones bad I'll trade dents with you. Mines at the fuel door which is waaay more reinforced than that side. You can see it in this picture
bubbaz28
Sep 18, 2015 02:09 PM
