upgrade wiper arm third gen
Old Dec 7, 2011 | 07:56 AM
maverickhatter's Avatar
I have been browsing through and wondered if anyone had a swap for the third gen wiper arms to change them to the new beam style or even the clip on connectors.
Old Dec 7, 2011 | 08:13 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Re: upgrade wiper arm third gen
i would like to know too
Old Dec 7, 2011 | 09:37 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Swap? The should be plug-and-play. You don't need to replace the entire arm, just the blades.
FWIW, if you have "wet" arms, the beam type blades may keep the windshield from getting a good spray pattern across the glass.
Edit: The Rain-X Latitudes may not clear the back edge of the hood. I have frame-type Anco blades and they come pretty close to the edge of the hood.
Old Dec 7, 2011 | 09:44 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im getting trico tech memory blades. hoping they clear since they are the curved blades aswell
Old Dec 8, 2011 | 02:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
AFAIK, those new Bosch wiper blades (whatever they're called, but they're like $25 a side), still don't have an adaptor for our older pin type attachments. I had a set of Trico blades that were similar (Innovisions, I think, they were $15 per side), and I STRONGLY advise against those. I split 2 on the driver's side in less than a year, WITHOUT snow. I currently use some super-cheapos that cost me $4 per side and wipe a TON better than those things.
Old Dec 9, 2011 | 12:46 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Same here, I had the expensive molded rubber Trico's on my '02, and they wouldn't properly stay on the car even with the correct adapter, much less do a good job of wiping the windshield. I'm currently using the expensive Rain-X equivalents, which (assuming they have the correct bayonet style pin adapters) should work great on a third gen since the windshield is completely flat.
Old Jun 20, 2012 | 01:37 AM
Possumz's Avatar
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 5 Speed
Axle/Gears: 3:42
I want to change the arms to the umbrella style hook on the end instead of the pin type. I have had so many come loose from the pin and dont want to scratch my new windshield I just had installed 2 days ago. So has anyone went from pin to j hook arms yet.
Old Jun 20, 2012 | 01:49 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If your wipers have come loose, you installed them wrong. I'm amazed at the amount of people that incorrectly install wipers and apply rainx/aquapel/rainshield.
Yes people have swapped. The wiper arms are two piece. The end piece with the pin mount uses a single rivet to hold it to the base. Find some J hook arms at the junkyard and drill out the factory rivet and rivet the 'new' ones to your factory bases. I can't remember which side has the bend in it but it's fairly simple to duplicate with a torch or something.
FWIW, even with the J hook mount I rock the Bosch Excel wiper blade + rain x and have excellent visibility. Excels can be used on pin style mounts as well.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
zayne0
Aug 24, 2015 07:22 PM
slade5612
Aug 11, 2015 07:19 PM
