Starting tomorrow! Any suggestions??
Old Dec 18, 2011 | 08:10 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
I'm starting on the body work and paint prep tomorrow for the IROC. There are a few bad spots that are visible around the rear quarters. Are there any places that I need to take a 2nd look at on these cars??? This is my 1st 3rd gen purdy up so any help would be good. I'll post up progress pics through out the week. Should be driving it by next Sat!!
Paint will be Cyber Grey Metallic (new Vettes and Gen 5 Camaro color)
Old Dec 19, 2011 | 09:59 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Re: Starting tomorrow! Any suggestions??
I took my 91 RS apart to find rust and you'll be surprised at what you find if you do. If you plan on keeping her then I suggest removing all the body parts you can and fixing any rust spots....especially in the cowl/cowl drain area, bottom fender where it bolts to the body behind the tire, inside the hatch/quarter panel, strut towers and floor pan. If you see rust on the outside quarter panel area it's probably the tip of the iceburg.....dig dig dig and do some searches on this site...lots of rust areas on these machines. If you're just going for a spray and pray then good luck!
Old Dec 19, 2011 | 10:29 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
there is alot of rust areas on these cars i found out the hard wat with my project car. heres a short list of spots to check:
1. if you have the front fenders off behind the front wheel well
2. rear wheel wells by seams
3. battery tray
4. rad support
5. floorpans
6. trunk drop offs
7. firewall below a/c thing
8. bottoms of doors.
9. rear bumper reinforcement
10. if you have ttops look at the bar
11. trunkpan
12. deck lid
13. in front of rear wheel wells
you probably wont have any since your down south but never hurts to check
a majority of this list is spots i foun rot on my car
Old Dec 21, 2011 | 09:14 PM
Car: 1988 Iroc-Z
I can't post pics from my phone so I'll upload them Friday or sat. Got all of the body work and most of the taping finished. Putting new door hinges on tomorrow morning and prime n paint around 2/3. Cyber grey metallic is the color and I MIGHT do the ground effects a shade of silver metallic but not 100% sure yet... Guess I'll make that decision when it comes time to shoot the car... The best part about this job is its FREE... Parts, paint, labor... Lovin my girls step dad! He's the **** lol
Old Dec 27, 2011 | 11:27 AM
Car: 1988 Iroc-Z
Pics coming in a few min!!
Old Dec 27, 2011 | 11:43 AM
Car: 1988 Iroc-Z
Ok, I'm going to do a "body & repair" post and a "Door Hinge repair" post...
Old Dec 27, 2011 | 12:14 PM
Car: 1988 Iroc-Z
1st pic is 30 min after I pulled it in the shop.
2nd Pic is the same
3rd pic is initial sanding w/ 220 grit
Attached Thumbnails Starting tomorrow! Any suggestions??-before-small.jpg   Starting tomorrow! Any suggestions??-before-1-small.jpg   Starting tomorrow! Any suggestions??-220g-sanding-small.jpg
Old Dec 27, 2011 | 12:18 PM
Car: 1988 Iroc-Z
2nd pic: done w/ metal glaze to repair a small dent
3rd Pic: the wheel well had a small amount of decay to it and was rebuilt with metal glaze
Attached Thumbnails Starting tomorrow! Any suggestions??-body-small.jpg   Starting tomorrow! Any suggestions??-door-repair-1-small.jpg   Starting tomorrow! Any suggestions??-passenger-rear-wheel-well
Old Dec 27, 2011 | 12:28 PM
Car: 1988 Iroc-Z
1st and 2nd pic: had to fix a small crack in the front ground effects w/ metal glaze... that should never break lol
3rd pic: Had some rust in the TTop pillars so we had to get rid of it... Not exactly sure what he put on it, but its some of the best stuff i've seen for filling small holes. Absolutely no leaks, what so ever!
Attached Thumbnails Starting tomorrow! Any suggestions??-front-repair-1-small.jpg   Starting tomorrow! Any suggestions??-front-repair-small.jpg   Starting tomorrow! Any suggestions??-ttop-repair-small.jpg
Old Dec 27, 2011 | 04:12 PM
Car: 1988 Iroc-Z
For the hinge repair: remove the door and air hammer the rivets for the TOP hinge off, leave the part of the hinge that attaches to the door on.
You can see the size pipe we used in the pics. Get it about 6-8 inches and cut it down to about 1/8 inch from the outside edge on both sizes so the bushings will fit correctly.
Weld it into place and buy a GM door hinge repair kit and also buy the assorted pack of bushings, trust me you'll need them. You'll have to get a 3/8 drill bit to shave some metal out of the door side bracket.
The door pin will have to be longer than the Camaro kit so just measure the length and get the right one. put it all together and bolt the door back on and you'll have a door hinge that is 100% rebuildable... Have fun!
Attached Thumbnails Starting tomorrow! Any suggestions??-hinge-2-small.jpg   Starting tomorrow! Any suggestions??-hinge-3-small.jpg   Starting tomorrow! Any suggestions??-hinge-5-small.jpg
Old Dec 27, 2011 | 04:25 PM
Car: 1988 Iroc-Z
Mostly finished product.
Next weeks goodies:
IROC decals (Black) and ground effect inserts
New louvers (Black)
Door and TTop weatherstripping
Window sweeps.
Panhard Bar
After 1 Jan:
Window Tint
Subframe connectors
Audio goods... (suggestions??)
Attached Thumbnails Starting tomorrow! Any suggestions??-base-1-coat-clear   Starting tomorrow! Any suggestions??-base-3-coats-clear   Starting tomorrow! Any suggestions??-base-3-coats-clear
Old Dec 28, 2011 | 04:53 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
That cyber grey metallic is beautiful. When I get around to painting mine, it's one of my top 3 choices. Dark Red, Cyber Grey, or Black.. On the repair for the spoiler, I was under the impression we had to use a flex agent or it would the repair of any kind would crack.. what do you think..?.. Stone
Old Dec 29, 2011 | 11:37 AM
Car: 1988 Iroc-Z
So far so good... This stuff is literally like steel so I'm hoping I wont have any issues with it... If I do, I'll just replace it and do a repaint.... BTW, the paint I went with is about 700 per gallon, so be prepared to come out of pocket lol
Old Dec 29, 2011 | 11:40 AM
Car: 1988 Iroc-Z
in the sunlight, you will fall in love with the color. It has just enough metallic to catch your eye but no so much that it looks like a "Pimp my ride" car. I'm going with all black extras... I'm still in the air on the rims, any suggestions? I'm really liking the y2k vette wheels...
Street Lethal
Apr 30, 2019 12:14 PM
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
drathaar907
Aug 6, 2015 04:20 PM
