need help removing dash
Old Jan 25, 2012 | 09:34 AM
891-92camaro's Avatar
Car: 92 camaro 25th anniversery
Engine: 350 TBI
Transmission: 700 R4
Axle/Gears: 3.73 9 bolt
I have a 92 camaro rs, i was in the process of finishing patching some rust on the pass. side kick panel and was almost entirely done with the rust repair on the car when a spark from the welder jumped up ontop of the heater/ac box insulation and caught it on fire. so to see the damage i took the dash out but i have the dash all the way off the fire wall and laying on the seats, and all connectors dissconnected but there is one harness that runs on the drivers side to the rear speakers and it looks like it goes to the center console also, there is no dissconect on this harness, so my question is how is the dash fully taken out?? is the harness taken out of the dash and left hang?
Attached Thumbnails need help removing dash-0124121955.jpg   need help removing dash-0123121940.jpg   need help removing dash-0124122106a.jpg
Old Jan 25, 2012 | 09:40 AM
Engine: 350 TBI
Re: need help removing dash
more pics of damage and the car
Attached Thumbnails need help removing dash-0124122048a.jpg   need help removing dash-0110121930a.jpg   need help removing dash-0218111655.jpg
Old Jan 26, 2012 | 07:02 AM
Engine: 350 TBI
need to move to interior???
Old Jan 26, 2012 | 12:17 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
The harness goes from the c100 (firewall) to the third member (fuel pump harness) with no dissconect in between. Not to mention it spiderwebs everywhere in between.
I have a complete interior A/C assembly if you have trouble locating one pm me.
Old Jan 26, 2012 | 12:53 PM
Engine: 350 TBI
yea i finally got the dash all the way out this morning had to take the duct work off the dash then take harness out of the dash. i already bought the inner heater/ AC box off thirdgenranch, but as far as the vats box can i just leave the pass key box out? because the vats system is disabled through my custom chip.
Old Jan 26, 2012 | 01:08 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
damn how messed up was it after you took off the dash?
Old Jan 26, 2012 | 01:13 PM
Engine: 350 TBI
it destroyed the heater box, melted the defrost ducts and pass key box, and pass key harness, and like 1ft of the harness that runs on the top of the fire wall, was not as bad as i thought it would be. water damage is prolly the worst.
Old Jan 26, 2012 | 01:15 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
dang, hope it gets better. oh i have a q. how do i know that my vats is making me not turn on car? what would happen?
Old Jan 26, 2012 | 01:22 PM
Engine: 350 TBI
i believe if the vats key is wrong or there is a fault in the vats system it will allow the car to start but will not let it run for over like 10sec or so. i may be wrong but i am pretty sure the car will star but not run if there is a vats problem. my vats is diabled through my custom computer chip so idk what the outcome will be if i do not put the vats/pass key box back in.
Old Jan 26, 2012 | 01:24 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
ahh i see. and how much did you get your chip for?
Old Jan 26, 2012 | 01:32 PM
Engine: 350 TBI
i just bought another ECM, my friend can custom tune so he burnt me a chip i just bought all the stuff.
Vintageracer
Jan 10, 2020 05:33 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
Street Lethal
Aug 14, 2015 08:25 PM
stalkier
Aug 13, 2015 12:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
