Rear hatch lift struts
Old Feb 16, 2012 | 10:12 PM
onebadd86t/a's Avatar
Car: 86 trans am
Transmission: 700 r4
Axle/Gears: 3.42 posi 10 bolt
Does anybody know if anyplace makes or sells a stronger pair of struts for the rear hatch.
Old Feb 16, 2012 | 10:15 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Rear hatch lift struts
Local auto parts stores
Old Feb 16, 2012 | 10:30 PM
nickfrmtx89's Avatar
Car: 1992 Camaro RS
Engine: 305 5.0L TBI
idk about stronger ones but you can get new ones at 1aauto.com. why would you want stronger ones, do you have louvers or something on the back?
Old Feb 17, 2012 | 02:21 AM
Car: 86 trans am
i have put on three pairs of struts from the local napa store all of them under waranty btw. I just thought that maybe there was a different brand that was better. I also know that you probably can't get any better than factory pieces but the gm dealer in my area is haveing a hard time getting them. No I dont have louvers I just want them to hold the hatch up for more than thirty seconds. two of the pairs had oil residue like they were bouncing around and the seals shot craps and the other pair just didnt work well one did but the other acted like it didnt have a gas charge right out of the box. ill try a different parts house to see if they are any better until then ill use the stick.
Old Feb 17, 2012 | 02:56 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Originally Posted by onebadd86t/a
local napa store
Well, there's your problem.
Old Feb 17, 2012 | 05:37 AM
Engine: L31 350
Try autozones strong arms
Old Feb 17, 2012 | 06:33 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
acdelco part # 510-509 for no wipers or louvers, or acdelco p/n: 510-510 for the heavy duty units. if you cant get delco, I advise sachs or monroe.
Old Feb 17, 2012 | 10:47 AM
1Aauto's Avatar
Former Sponsor
We carry them on our site for your Firebird. Free shipping too
Pontiac Firebird Hatch Struts
Old Feb 17, 2012 | 11:05 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
This is one area (and hood struts) that I will buy aftermarket. The GM ones just don't last.
Buy any that have a lifetime warranty. You'll prolly need it. I have been very lucky sofar . I put on a set of hood and hatch struts 20yrs ago on one of my cars and they are still working..
Old Feb 17, 2012 | 10:04 PM
Car: 1992 Camaro RS
i do notice mine get weaker in cold weather but living in the south its not that much of a problem
Old Feb 17, 2012 | 10:09 PM
Car: 86 trans am
Thanks everybody for youre input I might try to get the delco struts if not them ill give 1a tony a try. thanks again
Old Feb 17, 2012 | 10:19 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
IA Tony just had an ad on here today for supports. I think it said free shipping. It may have been for hood supports but it looked slightly cheaper. That said, once I've replaced them from the parts stores (Not NAPA...no offense), I haven't had a problem. Good luck
Old Feb 17, 2012 | 10:57 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I buy and sell only the ones spec'd for the rear hatch wiper motor. Strong Arm or SACHS.
Lon
Old Feb 17, 2012 | 11:49 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
They used to have different part numbers for z28 and RS. The RS were less pressure and allow the hatch to rise normally. When I needed to replace them, I bought the ones for the z28, thinking they should be the same. Not quite, they had much more pressure in them, and use to shoot my hatch up like a rocket, it was also really hard to shut.
The z28 uses the higher pressure struts for the heavier wing
Old Feb 22, 2012 | 02:15 PM
1Aauto's Avatar
Former Sponsor
Here's a video too, that will show you how to replace your hatch struts. Hope this helps yah out.
Tony
http://www.youtube.com/watch?v=qfIfW...9cxwPO3Jm7uJre
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
