Replaced triangle seals...still a lot of wind noise?
Old Feb 19, 2012 | 09:13 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
As the title says, I have a lot of wind noise even after replacing the triangle seals! They just don't seem to seal right to the window, and when I close the door they push in the weatherstipping along the a-pillar a bit. On the triangle seals, which way do they go? Should the side that has more go inside the window or outside? I installed them as the old ones came off. Maybe they were wrong before? I'll post pics if it's confusing. I'm not the best at describing.
Other than that, is is just the shape of the car that causes an unavoidable amount of wind noise?
Old Feb 20, 2012 | 10:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Replaced triangle seals...still a lot of wind noise?
sometimes these windows get wobbly over time too, so you may need to get into the door and adjust the window itself to get it resting just right against the roof rail seal too
Old Feb 20, 2012 | 04:01 PM
chevydrvr's Avatar
I thought that would be the case. How do I go about adjusting the window?
Old Feb 21, 2012 | 07:40 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
there are some really good photos and adjustment info here:
https://www.thirdgen.org/forums/body...dow-loose.html
Old Feb 24, 2012 | 05:07 AM
chevydrvr's Avatar
I might take it apart again today and see if I can adjust everything. If not I'll snap some pics to show you guys what i'm talking about!
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Mar 18, 2019 08:29 PM
pimp2303
Jul 27, 2017 02:03 PM
B_Dubya
Aug 26, 2015 05:09 PM
BlackBoulder
Aug 11, 2015 11:15 PM
