Rear hatch help
Car: 1984 Pontiac Firebird
Engine: none atm
Axle/Gears: 3:73 zexel torsen
Re: Rear hatch help
if you get a hold of a good locksmith there is a chance they can re-key the locks for you or they might be able to at least get your hatch open so you can replace the lock.
Car: camaro
Engine: 3.1
Transmission: auto
Re: Rear hatch help
my key wouldnt open my hatch. i poped off the hatch light and put a flat head on the inside of the lock twisted and it poped open. give it a try. you have better chances of opening it from the inside then the outside
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Rear hatch help
Have a new key made (or get new lock set), then you can lock your doors as well open your hatch.
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Rear hatch help
Have you checked to see if it's just a blown fuse keeping the latch switch from working?
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
Re: Rear hatch help
i feel your pain with no keys. my new gta didnt come with right keys .same thing with my hatch it clicks but doesnt release.
can we take our title to a dealership and have them cut a key based off the vin number?
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: Rear hatch help
You car is too old and most dealers don't have the info and don't want to be bothered. A locksmith can make you new keys.
My 84 didn't come with door/hatch/t-top keys and a locksmith came to my house
and made a new set for $30 bucks.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Rear hatch help
Yes,a dealer should be able to get a key for you with the vin and proof of ownership(title)
Re: Rear hatch help
Got mine popped just now.in a moment of brilliance(or dumbassness depending on how u look at it)noticed there wasn't any hatch support struts.had the gf push the button as I pulled up on the hatch.badabing!
Street Lethal
Apr 30, 2019 12:14 PM
