Door removal
Old Apr 29, 2012 | 07:22 PM
99olo's Avatar
Car: 1982 Pontiac Trans-AM
Engine: 283
Transmission: Saginaw 4 Speed
Door removal
On my '82 TA, my driver's door is done for.
I assume the removal should be easy, but I can't find anything about door removal on here.
Or on google.
And I don't know what the deal with the bottom hinge is... how do I undo it?
Many thanks, guys.
Old Apr 29, 2012 | 08:07 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Door removal
The hinges are welded to the door & bolted to the body. So you have to unbolt the door & hinge as 1 piece.
Old Apr 29, 2012 | 08:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Door removal
And the bottom hinge has one bolt on the outside and 2 15mm bolts on the inside, behind the kick panel and a piece of "sealing" rubber or plastic.
Old Apr 29, 2012 | 08:46 PM
99olo's Avatar
Engine: 283
Re: Door removal
So I don't need to worry about anything, such as the spring?
Old Apr 29, 2012 | 08:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
The spring will stay with the hinge... Done 5 doors now and haven't had a problem with the spring (except when I removed it to replace the bushings and couldn't get it back in again).
Old Apr 29, 2012 | 08:58 PM
99olo's Avatar
Engine: 283
Re: Door removal
You're my hero.
Old Apr 29, 2012 | 08:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
Worst part is that they were all on or for the same car... Stupid rust .
Old Apr 29, 2012 | 09:00 PM
99olo's Avatar
Engine: 283
Re: Door removal
All I have is huge dents.
Stupid previous owners.
Old Apr 29, 2012 | 09:05 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
I almost forgot... the one single passenger's side door I replaced because it was cheaper to get a door from a junkyard than to replace the outer skin after some a$$ punched a hole in it next to the lock to break in. If I had my 2-way pager alarm then, I might be just getting out of jail now for bashing his head in (the force he applied to the door skin would DEFINITELY have set off the alarm... Still wonder how he got through the skin without anyone hearing him POUND on the door). Stupid amateur thieves don't know anyone can break into a 3rd gen in less than 20 seconds without damaging ANYTHING... And the stupid cops didn't take the greasy fingerprints the thief left on the window...
Old Apr 29, 2012 | 09:09 PM
99olo's Avatar
Engine: 283
Re: Door removal
The stupidity of people amazes me.
Moreover...
What'd he take?
Doesn't he know that he could've stolen that thing with a slide hammer and a screw?
Old Apr 29, 2012 | 09:14 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
He took my 4-month old Eclipse stereo (but left the Sony sub and Jensen amp in the back even though I had a working hatch release), and my school tools out of the back seat. Didn't touch the ignition or anything, but smashed the door and the crap out of the radio pod I HAD JUST REPLACED before putting the stereo in (and apparently also the HU connector as the REMOTE wire was still hanging in the radio pod, terminal and all. It was clearly a smash and grab. Bet he didn't know the HU was locked.
Old Apr 29, 2012 | 09:28 PM
99olo's Avatar
Engine: 283
Re: Door removal
A Mitsubishi head unit? Hope he gets what's coming to him.
I really hope that crap doesn't happen to me...
But it's not often a car gets stolen around here.
Old Apr 29, 2012 | 10:06 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
No, the Eclipse brand by Fujitsu Ten (which shut their doors last year)... It was a CD-3402 (I have another now) and was later replaced by their 5435. With a $100 Panasonic in the middle (since the stock HU I was given by a mechanic friend of the family absolutely sucked and the tape mechanism was broken and my stock one blew the rear channel due to a crossed wire ).
Old Apr 29, 2012 | 10:11 PM
99olo's Avatar
Engine: 283
Re: Door removal
That makes much more sense...
sounds really expensive.
Old Apr 30, 2012 | 06:53 PM
99olo's Avatar
Engine: 283
Re: Door removal
Well, I found exactly what I was looking for...
The day after I needed it.
https://www.thirdgen.org/forums/body...r-removal.html
I don't understand why it wasn't the first to pop up, that's exactly what I searched.
... how do I get that kick panel off?
Old Apr 30, 2012 | 06:55 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
One screw in the middle of it and possibly another by the sill plate... Lift the bottom and pull up and back.
Old Apr 30, 2012 | 08:05 PM
99olo's Avatar
Engine: 283
Re: Door removal
What's the box...
More specifically, what's a "window relay"?
It's not an automatic window...
Old Apr 30, 2012 | 08:10 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
No window relays on your car... On mine, maybe (I just put them in today).
The box is the door lock relay...
Old Apr 30, 2012 | 08:12 PM
99olo's Avatar
Engine: 283
Re: Door removal
... for an electric door lock?
Is it just an add-on, and do I need it?
My dented door that came off had no such thing...
Can I cut the wires and be rid of it, and have it all be good?
Old Apr 30, 2012 | 08:15 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: Door removal
I'd leave it in case you want to add keyless entry later. It's not really in the way of anything other than the door bolts.
I'm assuming, of course, that this box has a single screw on the left side and about a dozen wires coming out of the bottom... And it's metal.
Old Apr 30, 2012 | 08:17 PM
99olo's Avatar
Engine: 283
Re: Door removal
Yeah.
... and the door's going on a car with nothing electric...
The way I like it.
Old May 1, 2012 | 10:47 AM
99olo's Avatar
Engine: 283
Re: Door removal
One last thing...
Is there an easy way to take the spring out and put it in, without special tools?
Old May 3, 2012 | 07:43 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Door removal
Originally Posted by 99olo
One last thing...
I popped out the one on my jimmy with a prybar and reinstalled it with this.
Got it local off the shelf
http://www.harborfreight.com/gm-vehi...ool-95344.html
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
