proper way to remove a door
Old May 27, 2012 | 03:06 AM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
Hi, I was wondering when you remove a 3rd gen door, do you wanna unbolt the hinges from the body or the door? In other words, when your done taking them off, will the hinges be left on the door or the body of the car. The goal would be the easiest way to re-align it when you put them back on. I would be removing them to paint the door jams and don't want to mess up the fresh jams with a mis-aligned door. Thanks...
Old May 27, 2012 | 05:49 AM
rffy's Avatar
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
Re: proper way to remove a door
Every time I have done it I left the hinges on the door. The 2 doors I bought off of craigslist also had the hinges attached to the door when I bought them.
All of them went off and on easy enough.
Hope that helps.
Old May 27, 2012 | 06:16 AM
rob2000gt's Avatar
Car: 91 Trans Am GTA
Engine: Tpi 5.7
Axle/Gears: 3:23
the hinges are welded to the door and bolted to the car
Old May 27, 2012 | 06:40 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
EXACTLY....
Old May 27, 2012 | 08:01 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Any tips for disconnecting the electrical wires?
Old May 27, 2012 | 04:26 PM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
oh, that makes sense. I can't look at the car cause i'm in Afghanistan. Just trying to get a game plan for when i get home. How hard is it to align the doors back up. Is there alot of adjustment there, or just bolt back on?
Old May 27, 2012 | 04:54 PM
J91's Avatar
J91
Yes remove the interior door panel and unplug the wires...
Old May 27, 2012 | 07:51 PM
peterc005's Avatar
Transmission: T700
Are the plug connectors inside the doors or inside the car?
I assume there is a single connector, rather than having to disconnect mirrors, windows and locking separately?
Old May 27, 2012 | 08:02 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
The connectors are all inside the door. Remove the door panel and unplug the power windows, power locks and mirror (if you have any of these). Then remove them with the rubber boot from inside the door jam. You can pull each wire through, but it isn't fun, but I have done it.
Old May 27, 2012 | 08:24 PM
J91's Avatar
J91
Never assume w/cars! There is not a single connector. That would make good sense, but it is not cost effective. Like I said take off the door panel and unplug the wires. He's right you can pull the wires through and it is not any fun...
Old May 27, 2012 | 11:38 PM
peterc005's Avatar
Transmission: T700
Thanks for the tips.
I need to remove my doors for repairs and was unsure about the wires.
Old May 28, 2012 | 03:36 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I cheated and suspended my door from a rafter and jacks, and just stretched the harness out to suit. There was just enough barely length to change the hinge pins and repaint the jamb (only did rh door).
Couldn't believe there weren't connectors inside the cabin like pretty much every other car I have owned or worked on - pita!
Old May 28, 2012 | 04:49 PM
rob2000gt's Avatar
Engine: Tpi 5.7
Axle/Gears: 3:23
aligning the doors suck a$$ im still working on aligning the one that I replaced on a camaro. it is the worst vehicle to do it on because the doors weigh so much.
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
