ASH Tray LIGHT
Old Nov 16, 2000 | 12:16 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
ASH Tray LIGHT
Ok i was lookin one day and found a ashtray lihght under my dash and hooked new bulb into it but it dosent work and isnt getting power i looked around the ashtray for a switch but no switch whats up with that light and how do i get it to work.
Old Nov 16, 2000 | 01:43 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
turn your lights on and test again for power...
Old Nov 16, 2000 | 01:56 AM
FAST RS's Avatar
i allready tried that. But since its an ashtray light shouldnt it have a switch so when i open the tray for the light to comon.. I really want it to work even tho ill neer use it its just some sort of ting i have that if its broke fix it and ovysely thats broken
Old Nov 16, 2000 | 07:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
On my 85, the "light" is just a piece of fiber-optic cable that runs from the bulb near the shift indicator. There is no switch or anything like that.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Nov 16, 2000 | 02:28 PM
FAST RS's Avatar
Mine is benight my center airvents like on the bottom of the dash and there are 2 wires there.
Old Nov 17, 2000 | 04:13 PM
PopaPork's Avatar
Yeah Fast RS. I got that to....mine dont work...can't figure out why...whut the heck is it for?
Old Nov 17, 2000 | 05:35 PM
FAST RS's Avatar
its suposto be a ashtray light im jsut gonna rewire it to my console light so when my ligts are in it will be on
Old Nov 18, 2000 | 04:26 PM
CanadianCamaro's Avatar
Car: 1992 Camaro RS
Engine: 5.7 V8 TPI
Transmission: T-5 5-Speed Manual
My Car has the "ashtray" light on the underside of the dash too, only mine works (just had to put in a bulb). The problem with it is that the bulb & hole are so small that the light doesn't shine on anything (you have to hold your hand 1" from the hole just to make sure the light is on). Im going to replace the bulb & holder with a more common 194 bulb
Black 87 Camaro T-Top, V6, 5-speed, Loaded
see my car at: http://www.geocities.com/iCamaro1987/camaro.html
[This message has been edited by CanadianCamaro (edited November 18, 2000).]
Old Nov 26, 2000 | 08:57 AM
Pat Hall's Avatar
I have the same light on my 89RS. All I had to do to make it work again was change the bulb. It works on the same power supply for the rest of your dash lights. Like the other guy said, it's pretty dim even when the bulb is working. I.E. it has to be pretty damn dark inside the car to even notice it! If you can't get any power to it, just do like you were saying, and run a jumper wire to your shift indicator light wiring on your console for power.
Old Nov 27, 2000 | 04:15 PM
sguy30's Avatar
I have the same thing in my car, has been stumping me for years. I guess you could make it a halogen map light if you wanted.
'87 IROC, 305TPI, 5Sp, , 170K miles, all original except for K&N filter, Vin F
Old Nov 27, 2000 | 11:35 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The light is slightly different design for my 88 Iroc and 90 RS, but both have a very small hole. I contemplated opening up the hole to let in more light, but I figuired instead it is purposely designed to have a very small hole. That way it works like a pinhole camera, letting an even low level of light over a wide range of angle. Opening the hole would focus more light over a narrower angle destroying the effect intended of a diffuse ambient light.
Old Nov 29, 2000 | 09:42 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Ive got the hole under my vents, but no light, or harnass for that matter! I dug all around in my dash for it, but didnt find a thing... Anyone know how I would wire one in?
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!! (New thing!)
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (17:24:14)
"No one knows until they learn" Leon Calrinsky (99)
Old Feb 22, 2018 | 11:07 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Re: ASH Tray LIGHT
kiztope did you ever find the wire to plug into on your 1992? Was it taped to another harness somewhere?
Old Feb 22, 2018 | 03:35 PM
Drew's Avatar
Re: ASH Tray LIGHT
Wow! Bumping a 17+ year old thread for the most useless light ever... That is dedication.
Some thirdgens don't have the wiring for the light. Just the way it is. You might find a pigtail for the light somewhere in the dash harness, but it's really a waste of time to even bother looking, since it's a useless light even when it's there.
Old Feb 22, 2018 | 03:54 PM
Re: ASH Tray LIGHT
Commenting with a useless opinion to bump your comment count is the real dedication.
Old Feb 22, 2018 | 04:32 PM
Drew's Avatar
Re: ASH Tray LIGHT
I couldn't care less about my post count. You asked a question and I gave you an answer. It's extremely likely that if your car doesn't have the light, it probably doesn't have the wiring for it either. Unlike many other options, that specific plug usually isn't there. And it's certainly not worth adding it, since the light projected by the factory setup is extremely limited. Like if you're in a pitch black room, but can see a light through a pin hole from another room, but only in your peripheral vision and it disappears when you look directly at the light source.
The better solution if you need more light on the console would be to get a rear view mirror from a later Firebird. They have the console light in the spot normally occupied by one of the map light switches, and that light actually casts a bit of light.
A very small diffused LED would cast more light than the normal Camaro console light.
PS It's bad manners to bump an old thread. It's really bad manners to bump 30 classifieds threads asking for parts that aren't listed in the thread, and that can be found in any junkyard in America, or new from GM. Seriously, aside from a select few of us, most members aren't watching threads from 6 months ago, much less 17 years. Try using the Private Message system, or email.
Amazon Amazon
Amazon Amazon
Old Feb 24, 2018 | 08:21 PM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: ASH Tray LIGHT
It wouldn't suprise me if ol' welcoming and friendly drew would of been bustin'
the guys chops with a friendly "WHY don't you do a SEARCH instead of askin' here"
or "why don't you post in a existing thread" if he posted a fresh thread! {sic}
"shakes head"
Old Feb 24, 2018 | 09:26 PM
Drew's Avatar
Re: ASH Tray LIGHT
"shakes head"
You act like I'm the only one that points out when someone bumps an old thread, or suggests searching old threads. Sorry I don't take more time to sugar coat my comments. They aren't intended to be hurtful, I guess some people just have extremely thin skin.
If you have a problem with my posts sonjaab, you can always add me to your block list and you won't have to read them.
Edit: See? It's easy.
Old Feb 24, 2018 | 09:48 PM
Re: ASH Tray LIGHT
Bad manners to ask guys that parting out cars for parts? No. You are wrong. I've gotten PMs and responses and others are asking for parts to.
FYI Drew, here in DFW area the F-bodies are long gone. If you find one in a bone yard it's a skeleton.
No one should be talked down to for asking a question on the boards, that's the bad manners I see in your posts. Its not up to you if the question is value and you don't need to say a word if you don't something to contribute.
It's not about sugar coating anything. It's about contributing in a professional way.
Old Feb 24, 2018 | 10:37 PM
Drew's Avatar
Re: ASH Tray LIGHT
Other people are hitting those threads because they don't realize that they're old threads that you've bumped to the top.
You don't need to find a thirdgen to find a relatively common socket used for marker and interior lights on many applications.
I did have something to contribute, you're just focusing on my amusement that you bumped a thread old enough to vote.
I'm not a professional forum poster. I'm not on a payroll. I do this for fun. If I see someone doing something goofy on the forum, wasting their time and the time of others, mucking up the works, I'll generally take a moment to try to help that person understand what they're doing and find a viable alternative. That's not talking anyone down, it's constructive criticism. I just didn't realize you were so sensitive that it'd hurt your fragile feelings.
Old Feb 24, 2018 | 10:55 PM
Re: ASH Tray LIGHT
You're just a message board troll in denial.
Look at your posts, telling people not to bump, finding amusement, telling people to block you cause you can't stop posting, thinking you are hurting other feelings, arguing.
Turn the computer off and go work on your cars man.
Old Feb 25, 2018 | 02:45 AM
Drew's Avatar
Re: ASH Tray LIGHT
Trolls don't usually contribute to forums. They usually haven't written tech articles, edited lengthy guides, or served as a moderator. They don't generally take the time to answer questions or scan and upload diagrams, etc.
I'm not telling anyone to do anything. I joked about your bumping a really old thread, and addressed the question you were asking. I even went out of my way to show you a few workarounds that might help you reach your goals. It's not my fault you can't take a joke, or criticism, or advice.
I've been active on this forum since the beginning. I'm not going anywhere.
Old Feb 25, 2018 | 11:16 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: ASH Tray LIGHT
So now he starts name calling................
shame shame........
Old Feb 25, 2018 | 05:18 PM
88txiroc's Avatar
Re: ASH Tray LIGHT
And without further ado.... This thread will now be closed. I honestly don't see it getting any more "useful". Let's try to keep it friendly and helpful.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
