I want a digital dash! Please help!
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Ive got an 89 GTA. I want to install a factory digital dash in it. Where can I find one? Id also like to know whats involved in changing over. My friend said id have to change the ECM. I dont believe him. Maybe the sending units for the gauges I can understand. I hope its not a pain in the *** . I just finished painting the car black and the dash would really top it off! THX guys!
Check out http://www.tacreationsusa.com. I was there a week ago and they have a digital dash available. I asked about it myself and they said there's alot of modifications that need to be done to make it work.
sorry but it aint happening. You will need a donor car. It's a whole different wiring harness.
not worth it. Go get some white face gauges from Ryan instead.
'92 Formula
305 TPI
Mods: SLP catback,SLP air foil,ported plenum,Crane AFPR (49psi),MSD6AL,homemade cold air,K&Ns,3:73s,JET fan switch...SLP 1 5/8ths are coming...oh yes
'92 Formula
305 TPI
I installed a digital gauge from cyberdyne sytems. It is not factory but is a perfect fit for firebird and camaro dashes. You can get one from jeg's or summit racing. There about 350.00.
[This message has been edited by elektec (edited November 15, 2000).]
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I too was interested in this swap. It is a pain, but I talked with a guy who did it. He said the wiring harness has all the wires you need but you have to find them. Other than the dash then, you will need the sensors for the various things.
James
James
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I have the Cyberdyne unit and I'm willing to part with it for a lot less than $350. All I need is a 140mph speedo and gauge cluster in exchange. The only problem with my digital display is that the speedo isn't working. There's supposed to be some kind of calibration box that I can't find. Otherwise, the tranny mounted sensor is there and all the rest of the gauges work perfectly fine. Yeah, the stencil on the LED that should say OIL wore off so it lights up as one block.
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel
Ram-air setup coming soon
Flowmaster muffler
Taylor SpiroPro wires
Accel cap and rotor
'88 IROC 305 TPI
Gutted airboxes
160 degree T-stat
Momo steering wheel
Flowmaster muffler
Accel cap and rotor
I have an 88 trans am with a digital dash and gta body kit + gta rims. I think the digital dash sucks i want a regular one. when your going fast or racing (when you need to keep your eyes on the road )its to hard to see your speed or rpm's also its hard to see when its bright out (and i have 0 tints on the sides and 5 on the rear)but you know they say the grass is always green'r on the other side.
Car: 1990 Formula
Engine: 5.7 liter
I have experience...unfortunatly,its a result of bad judgement.
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
