slow Power Windows
Old Dec 7, 2000 | 10:56 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
slow Power Windows
If my windows go up and down slowly does this mean the motor is bad??
If it is normal can I get a newer motor (out of a newer car and put it in??
Also how hard is it to install a new motor??
aka:15 year old camaro freak
owner of a 91 z28 5.7l camaro
Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Trans Go Shift Kit, 2k Stall, B&M Rachet Shifter, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Dec 8, 2000 | 10:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
More than likely, you simply need to clean and relube the tracks with white grease. Do the power locks at the same time, if you have them. Worked wonders on the 85 IROC.
JamesC
Old Dec 8, 2000 | 10:57 AM
Ehelmsin's Avatar
I was about to ask this same question... some of my buddies car windows go up/down at lighting speed, mine look like I have a gerbil on a wheel rather than a motor... I guess I got to get in there and get cleaning.
Old Dec 8, 2000 | 01:00 PM
KS91Z28's Avatar
My experience with the window motors has been that if they are slow now, they will eventually stop working alltogether. sounds like they are on their way out. Mine are doing the same thing, but I'm just waiting for them to completely die.
Old Dec 8, 2000 | 02:16 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
James C
I just lubed my rubbers (ooer) on my 87 IROC and it worked wonders. Incidently, so did the sentral locking as it was all gunked up with crap.
Try that before getting replacements and allow time to let the grease do it's stuff.
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Old Dec 10, 2000 | 03:14 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I should have looked harder, I just posted a question about the windows a few minutes ago.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Recaro Seats,
Alpine CD+Changer,Rockford & Soundstream Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
WS6 Trans Am
Old Dec 10, 2000 | 08:44 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Hmmm, maybe thats why my power locks dont quite lock my car anymore....
Any tips on getting the doorpanels off without breaking anything? Ive never taken them off...
Thanks,
Daniel
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Dec 11, 2000 | 02:14 PM
JamesC's Avatar
Remove the arm rest, work a flat-bladed screw driver under the front portion of the door lock and carefully pry upward. Once the lock is removed, turn your attenion to the door handle plate, which has several false torx heads--put a magnet to them or you'll round the plastic out. Once you have the plate off, use a screw driver to pry the door panel's plastic studs from around the outer portion of door frame. The long black plastic piece that runs along the top of the panel is holding the door panel in place at this point. With the window down, push in on the black plastic and pull up.
JamesC
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
