changing a fender
Old Dec 21, 2000 | 05:03 AM
ihateallmustangs's Avatar
changing a fender
how hard is it to change the front right fender..and bumper cover? any special tools needed for the job? thanks.
Old Dec 21, 2000 | 08:51 AM
KS91Z28's Avatar
Neither one is hard at all, though you may need a second person to hold the new bumper cover up while you bolt it up. The only tools you should need are a set of metric sockets and some extensions.
Old Dec 21, 2000 | 11:57 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
And you have to take the hood off right?
James
If the women don't find you handsome they should at least find you handy
Aftermarket T-56 (pain in the A$S but worth it)
Lots of things to do still
Old Dec 21, 2000 | 02:51 PM
KS91Z28's Avatar
Yup
Old Dec 21, 2000 | 11:06 PM
86ZRICHIE's Avatar
yep, hood, bumper cover. I'd say the hardest part is getting the bumper cover off, it's a pain to get to those top nuts, I just used a regular 10mm wrench. it's not too bad of a project, and the results are well worth it
Old Dec 22, 2000 | 04:48 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you've got somebody to help you, removing the hood is not necessary. One guy can lift it up a tad after it's unbolted while you get the fender off, then set the hood back down and throw a bolt or 2 back in to keep it in place.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Dec 22, 2000 | 05:59 PM
ok, thanks for the info.
Old Dec 23, 2000 | 10:21 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Just a FYI. Sometimes the sheet metal containing the bottom bolt for the fender has been folded over by someone incorrectly jacking the car. It needs to be unfolded before you can get to the head of the bolt. I had this experience pulling the fender for the first time off a wrecked car and thought "what a stupid design to install the bolt, then fold over the panel". Then I found out it isn't that way originally. Only when a stupid car owner or mechanic jacks tha car incorrectly. Good luck, Lon.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
kah992
Aug 19, 2015 02:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
kyleb24
Aug 15, 2015 08:24 AM
